Svet's Fermi/Kepler VBIOS/EC-FW Tuner - [ver: 3.25t]
xavierland
Hi Svet's, I have a GTX 690 video card, and (for almost 2 years) the card doesn't scale to fullscreen when my system post. Also, when I enter the bios it looks like a center square with black borders at the sides, I know that this doesn't happen to me only, but all the 600 and older series users when pairing with a DVI/HDMI/Display port monitor. This has been a headache for long time, the only fix that I encountered is to update my card to the latest UEFI vbios and dissable CSM in bios. Doing that makes the video card scale correctly at post, but the downside is that you can't boot your other devices at post, even the bios when the system boots it goes directly to start the OS so fast that you don't have time to press the Del button, or start another OS in DOS. You're a fermi/kepler programing expert, and I remember a tool for fermi cards that fixes this scaling problem called Nibitor, in the "more boot options" you have to mark two "Force adapter scaling", and "Non-native panel control". That fixes this issue for fermi adapters, but this tool is discontinued and doesn't support kepler adapters. If you could add those options in the Vbios EC turner for kepler adapters, (so I don't have to dissable the CSM and enter in UEFI mode). I'd be very grateful to donate and help you in your project development.
Thanks in advance!!
EDIT Svet: Hello, i may take a look about this. Check PM for queries.
jmphillips332
PRIVATE FIRST CLASS
Hi Svet,
I haven't used your program for a while now and I have version 2.45b.  I have tried to use the updater and it downloads a file, but doesn't seem to fully update.  What do I need to do to fix this?
Thanks for your help and your great program.
EDIT Svet: Hello, too older versions have issue updating due changed server in future versions.
Checked you, and sent you the latest version.
makiboum93
hi svet, i have a msi ge62-6qd Skylake cpu and i was wondering if your software can help me to control fan to be more silent. what i want is to be able to fix the percentage in function of temperature.
EDIT Svet: Hello
Yes it allows such customizations, check PM for details
cosborn85
I Have a GE72 6QD APACHE PRO 003
and when im running mainly steam games I.E FOREST is the worst my GPU temp creeps up to around 70.c and some time over
and my GPU seems to throttle and crash the game ive read up on a few forums and this seems to be pretty common
does your software allow me to increase the throttle temp of my GPU?
im abit of a noob so not 100% sure is this is even possible can you help please?
EDIT Svet: Nope, the tool can't help with this.
If your notebook is crashing, best send it back to reseller or MSI for repair.
Or open own topic in notebook section for troubleshooting.
zaunersimon1987
Hi Svet,
I have MSI GS60-6QE16H11. The CPU fan is constantly pretty loud and I'd like to control it. Will it work with your VBios? Can you send it to me? How do I donate?
Thank you!
EDIT Svet: Nope, vbios can't control the FAN.
You can use the tool to modify and change the FAN behavior for CPU/GPU,
all details are in the 1st post.
Check PM if needs.
BigKid
I've been away for a while... Any news on the GTX980M front ?
Would still love to be able to custom tune my vbios with your great tool.
periskop
I can't copy row to row in EC BIOS Editor. If I put ae or another two letters, I get message "wrong parameter". Why?
EDIT Svet:  If you use it over Skylake based one, its normal.
Due limitation only one value there can be changed at the time.
periskop
There is somthing strange with FAN table. This is original Table
With this table as you can see CPU FAN always on" at speed around 3200 RPM. I've tried different modifications. Here is the last two of them
But at temperature till 55?C FANs always of (with this or other modded table) and than at 55?C they are starting. And with hysteresis 10?C at 45?C they are switching off. With different tables algorithm is even. Somthing wrong here, but I don't understand what.
EDIT Svet: If you need assistance, check PM for queries.
@mjtrapani
I've removed your reply as its not related to the tool,
i've answer you via PM instead.
n4ntek
CORPORAL
Hello Svet!
I got myself recently a GE62 Apache Pro. I had to update it's old EC fw to the latest version. After the update though, As i've learned the new FW also made changes too the so called fan table. EC reset didn't fix it so my only option was to use your tool to modify the EC's fan table. The problem is there are tables 3x for cpu and gpu, which was a bit confusing. So I had to ask what each of these 3 tables represent escpecially for the CPU fan. My plan is to lower the threshold point to what temp the fan should kick in, right now it's going constantly at the lowest rpm.
EDIT Svet: Hello
see here about multiple rows: https://forum-en.msi.com/index.php?topic=148273.msg1443679#msg1443679
Else if you need assistance check PM for queries
Administrator
Version has been updated  [3.07b==>3.08c]:
Changes:
* Update 670GTX: Improve compatibility
* Update MSI EC-FW Editor:
     - Build secondary separated Skylake's validation system for latest and newest Skylake's ECs.
silviu.hmz
Hi Svet
I have recently bought the MSI GS60 6QE-031ES with i7 6700 skylake processor.
One cuestion : Is this model compatible with your tool? I only want to tune up the fan noise, dont intend to do any OC.
If so please confirm,i will donate gladly.
Best regards.
EDIT Svet: Yes, model is supported for tweaking temp/fan curve for CPU/GPU.
silviu.hmz
Well this weekend ill receive my laptop so as soon as im trying it ill purchase the tool and will try to fine tune this machine.
Maybe i will need a little help,dunno. Keep up the good work! :biggthumbsup:
EDIT Svet: Oki, if you need further help after that i can assist you if needs,
you can message me and when i become online to able to assist you.
silviu.hmz
Hello Svet ive just purchased your tool And by the way the donator name ive used is dukehamza:)  I already have my laptop and i noticed that on idle only the right fan is running. And yeah its too loud to run at idle. So please send me the tool as son as you can. Anothcer cuesti?n: is it normal that my left fan on idle to be at 0 RPM?
I havent installed any game yet so i dont know if the left one is the one that kicks in when the dedigated gpu is under load so...im just asking. Anyway thanks again and ill keep this pc only if i manage to make it a Little quieter with your tool.
Best regards.
EDIT Svet: Has been sent to you
Yes its normal that 2nd fan, only should works when discrette nvidia card is in use.
2metragluposti
Hi, does your tuner work with non-MSI cards?
Specifically, Zotac 560 Ti AMP. I unlocked fan speed with another software, but fan needs to be controlled with software, fan curve is probably not correct in new BIOS and I can't correct it.
EDIT Svet:  The tool don't have a FAN curve control ability for this old class card.
thewebsiteisdown
Svet,
I noticed that my BIOS tuner is on version 3.07b still and not the newest one. Is there a reason why it hasn't updated for me? Do I need to do something to get it to update?
Thank you sir!
EDIT Svet: You have to run the included updater to check(and perform update) for updates.
Check PM for details if needs.
mocar.viktor
Hi Svet.
Hi Everybody
I know there is a lot of post about this laptop but i cannot loud nothing under Vbios Tuner. I did Vbios backup with GPU-Z. But after using your tools saying is not supported or cannot loud or invalid EC firmware.
I want reduce idle fan noise.
The machine is GS60 6QE Ghost Pro
Thanks for yours help.
EDIT Svet:  HI Viktor,
You have to load your EC firmware for your notebook in the tool [not the vbios]
and then to use the EC firmware editor to customize it.
EDIT2:
@myfatherwillhearaboutthis
Your post is splited since has no connection with the tool,
i've answer you in PM instead.
Lokys3010
PRIVATE FIRST CLASS
Svet, there is a BIOS and firmware for my gt70 2pc (domitator) suitable for windows 10?
robin.thomass
Hi There !
I've bought your software to change the fan setting but I'm wondering if I need to change all the tables ? Because I changed only the first two and now my fan is switching on and off erraticaly...
Could you please tell me what to do ?
Thanks
Robin
EDIT Svet: Hi Robin,
Depends, check PM for assistance.
gochoa
Hi Svet,
I have the same issue reported above by robin.thomass.
In my case, I changed all cpu rows.
What are the correct values?
Thanks!
Gabriel.
EDIT Svet: Hi Gabriel,
This issue can happens if you try to set a value that's outside of the hardware specs of the FAN(s).
Depends of your unit they are different FANs used
[typically for GS/GE series, the min acceptable FANs % [by the fan itself]
is around 44-48%, exclude fan off which is also an option,
setting min % below this would be FAN's outside specs, and the FAN will start doing a loop issues,
repeating endless /FAN off, high rpm/ in pattern loop.
But there are different methods to make the FAN more quite and also different possible custom combinations.
For GTxx series, the FAN's used there can run with lowest fan %, 20% [or some lower] ]
If you need help setup your customized FAN(s), temp(s) curve, check PM.
EDIT2 Svet:
@r.gapke
your post has been splited and moved to the proper area
grzegorznw
Hello Svet
I have MSI GS60 6QE with noisy fans
It's impossible to set it for about 1500 or 2000. Only 2900 or 0 - nothing beetwen.
Can Your software do it - Set CPU fan speed to 1500 or 2000 rpm ? (or any other value beetween 0 - 2900) ?
Thanks
