Svet's Fermi/Kepler VBIOS/EC-FW Tuner - [ver: 3.25t]
Administrator
Nope, because the FANs used in this notebook do not support such low voltage,
and setting such value, the FANs will not works correctly because it will be outside their hardware specs.
this for for GS/GE models
else we can set desired speed %, but if the fan can't take it it will not works correctly.
for GT models they can do a lower fan rpm
grzegorznw
Thanks for reply
Is it any other solution to set this laptop quieter - i don't do it anything special, only web browsing but the fans working noisy with 2900rpm.
EDIT Svet: The option between FAN off and 2900rpm don't exist for this model.
Else with the tool we can adjust many parameters and its possible to set it with fan off while you are doing web browsing only.
Check PM for details if you have interest in this.
mostafa.najafi1996
is there any hardware solution for set rpm between 0-3000 ?
for example change the fan or somthing else ?
can i control the graphic fan too ?
and is it has the same problem ?
if we can set it to rpm between 0-3000 then we can turn off cpu fan and laptop remain cool!
david@davidwaddington.com
Hi Svet,
I have a UK model GP62 6QF (gtx960)
Would your software enable me to switch off the cpu fan when its idling? Its constantly running at 3000rpm.
I installed dragon center (not the dragon gaming center) which initially worked ok, but the software has since stopped working, probably due to an incompatibility with a newer version of visual studio..so I have had to revert to the official dragon gaming center that does not support fan adjustment.
It would be nice to just be able to switch off or lower the rpm of the cpu fan when using the computer for light tasks..
Many thanks for your help,
DW
Administrator
Maybe, but i don't for such.
if the unit has 2 FANs, then both will have the same behavior.
yes fan off is an option
david said:
Hi Svet, I have a UK model GP62 6QF (gtx960) Would your software enable me to switch off the cpu fan when its idling? Its constantly running at 3000rpm. I installed dragon center (not the dragon gaming center) which initially worked ok, but the software has since stopped working, probably due to an incompatibility with a newer version of visual studio..so I have had to revert to the official dragon gaming center that does not support fan adjustment. It would be nice to just be able to switch off or lower the rpm of the cpu fan when using the computer for light tasks.. Many thanks for your help, DW
Yes, you will able to do this.
We can set desire values, but min/max FAN speed depends of the hardware parameters
For GE/GP/GS Series min possible varies from approx 2800-3000RPM
For GT series they can run with lower 1xxxRPM
Fan off is an option in all cases.
mostafa.najafi1996
And the lsat question!
if i use 0 rpm for below 60*, Will something happen for laptop chipsets or somthing else ?
EDIT Svet: Should be fine, those are idle temps.
sopisa51
CORPORAL
Hi, I have a MSI GE62 2DQ Apache Pro with i7 5700HQ and a 960m .
Would it be possible to increase the GPU temperaure throttling limit?
EDIT Svet: Nope
Administrator
Version has been updated  [3.08c==>3.09d]:
Changes:
* Update GTX980 Ti: add support for new vbios types +2
Desktop gpu's: extend PTS Base Power Limit range to 1kW for supported units.
* Fixed issue GTX580 can't adjust memory issue
* Update MSI EC-FW Editor:
     -  Fixed issue GT80 2Qx can't load some EC versions
     -  Add support for:
          * GT60 [16F4] Barabone
          * VORTEX G65 6QF SLI
          * VORTEX G65 6QD SLI
          * CX72 6QD
          * CR72 6M
          * GL72 6QC
          * GL72 6QD
          * CX62 6QD
          * CR62 6M
          * GL62 6QC
          * GL62 6QD
          * GL62 6QE
          * GP62 6QE LEOPARD PRO
          * GP62 6QF LEOPARD PRO
          * GL62 6QF
          * GE62 6QE APACHE PRO
          * GE62 6QC APACHE
          * GL72 6QF
          * GL72 6QC
          * GL72 6QE
          * GP72 6QF LEOPARD PRO
          * GP72 6QE LEOPARD PRO
          * GE72 6QE APACHE PRO
          * GE72 6QL APACHE
          * GE72 6QC APACHE
          * GE62 2QL APACHE
          * GE62 2QC APACHE
          * GE72 2QL APACHE
          * GE72 2QC APACHE
          * GS72 6QE STEALTH PRO
          * GS72 6QD STEALTH
          * GS72 6QC STEALTH
          * GS60 6QD GHOST
          * GS70 6QD STEALTH
aldozx
hello svet
I have a geforce EVGA 450 GTS here which the minimum fan speed is set by bios at 40% and is loud as hell on idle
I tried lot bios of bios editors to modify this bios trying to lower the minimum fan speed , but none of them worked or recognize this bios
your tool will work? help please
EDIT Svet:
Nope, this card is not supported by the tool
aldozx
thanks svet for your reply
but ,can you take a look at my bios if I upload it here?
you are the expert, maybe you can lower the min fan speed to 10% or so :pompom: help please
the bios is this : https://www.techpowerup.com/vgabios/104309/evga-gts450-1024-110524
EDIT Svet: Nope, sorry.
julienbarrault03
Hello. I come today to ask for help about an OC GTX 780m. A friend advised me to come to you on this. I struggle to turn Rise of the Raider even low. So I thought that OC would do.
(I'm sorry for my crappy English but I use Google translation).
e44pty
Hi
I've donated - and waiting for app :)
It's working on 970m? (GS40 6QE)
What's optimal voltage?
Has anybody try on 970m?
EDIT Svet:
The 970M series are not supported by the tool for vbios modification
(all supported GPUs are listed in the 1st topic)
But for NB model, the discrette GPU can be adjusted for temp/fan curve purpose only.
If need check PM for more info.
and waiting for app
since app. hasn't been sent yet,
check PM how do you wish to proceed further.
daan.janssen.nl
Thans! ;)
EDIT Svet:
@guitouoim
your reply has been splited and moved to the proper area
@manuelpetron
ozy_r
hello svet,
i have msi cx62 6qd (MS-16J6). my problem is about the fan speed. it never goes under 3200 rpm. i tried silent option and dragon center to reduce fan speed but i couldn't lower it. made some research and now im thinking it can be about firmware limitations (bios version E16J6IMS.107, EC version 16J6EMS1.106). i've checked your support list for editing firmware and i saw my laptop is supported. but i want to be sure if im going to make a donation. i want to reduce fan speed about 2000 rpm. can i do that whit your tool?
EDIT Svet: Hello
Nope, its a hardware limitation,  FAN to work at 2k RPM for this NB model can't be done.
such low speed its outside of the FANs spec of this model.
it can set such, but its not going work because of hardware limitation
ozy_r
well im trying to find a solution but i dont think i will. there is another issue about the fan. rpm goin up and down between 3200 and 3287. it is even more distractive. can this tool stabilize it to 3200 rpm?
EDIT Svet: There is always some % fluctations +/-, but this is near 100,
need to check it eventually, there could be a different reasons for this,
check PM if you want to take a look to give a 100% sure answer about this.
Administrator
Version has been updated  [3.09d==>3.10e]:
Changes:
* Fixed bug when do save and exit and if the source firmware is removed unable to generate modified firmware
* Fixed bug power thread can't load for some GPUs
* Fixed other minor bugs
* Some general code optization
* Improve compatiblity with Win10
* Fixed bug when combined Win10 + Symantec Endpoint Protection, cause a crashing issue when operating in threads
* Update GTX660: add support for new vbios type
   - addiction code optimization
  - increase temp threshold hysteresis value range to 25
   - Add support for:
         * GS63VR 6RF Stealth Pro
         * GT73VR 6RE Titan SLI
         * GT73VR 6RE Titan
         * GT73VR 6RF Titan Pro
         * GT73VR 6RE TITAN SLI
         * GT72VR 6RD Dominator Tobii
         * GT72VR 6RE Dominator Pro Tobii
         * GT62VR 6RD DOMINATOR
         * GT62VR 6RE DOMINATOR PRO
         * GS73VR 6RF STEALTH PRO
         * GS43VR 6RE PHANTOM PRO
         * GE72VR 6RF APACHE PRO
         * GE62VR 6RF APACHE PRO
EDIT:
kamy1375
reply has been splited and moved to the proper location
Jong In-KIM
Svet's Fermi/Kepler VBIOS/EC Tuner - [ver: 3.10e] --> Please update the New ver GTX 10XX  Svet's pascal VBIOS  / EC Tuner  schedule ???
