Svet's Fermi/Kepler VBIOS/EC-FW Tuner - [ver: 3.26u]
amar.albafaraj
Hi Svet, could you please help me the way for upgrading graphic card my MSI GT70 from GTX 675MX to GTX 970M, because everytime I install the driver it keeping freeze my laptop. Thank you
(Sorry for my English not really good)
EDIT Svet: Check PM
michel.steinbusch@ziggo.nl
Hi!
I was wondering if the 630m is supported, Fermi card, I managed to get the vbios using UEFI Tool, i'm using an Asus asus n73sm, it's using liquid metal on cpu and gpu, and currently stable at 822mhz +125 mhz!, without voltage increase.
The gpu does not get over 65C, quite impressive. This is just a hobby project to see what this little thing can do, and yes I know the risks involved :)
Best Regards,
EDIT Svet: Check PM
davysguan
Hey Svet, I intend to donate for your VBIOS Tuner tool but I would like to ask if the GPU core OC software limit removal feature works with my GK208 GT730M? I have attached the VBIOS that I intend to use the tool with if it helps.
EDIT Svet:
Check PM
weeman
Big thanks to Svet for the quick implementation, GF72 8RE is now also compatible with the EC-Tool!
seanwee2000
Hey Svet, Ken from gentechpc told me to come here as i need some help modifying the EC for my GS75 9SG to allow it to use more power.
Right now the EC is preventing me from using more than 230W and when i exceed that the laptop will switch to battery and back to AC and then back to battery again if the 230w EC limit is still exceeded.
Can you help?
Thanks a million!
tiagobar1995
Hello, its possible disable Igpu on msi gl 62m 7rdx with this bios tunner?
Thanks
EDIT Svet:
Nope, the tool can't modify system BIOS.
xi.avatar6
I was wondering if the EC-FW tuner will work on the GS66-Stealth? I want to change the temps at which the different fan speeds are triggered.
Administrator
Nope, those new models are not supported, at least not yet.
xi.avatar6
Do you have a rough estimate on when you think you'll add support for the GS66 in the future?
The current temps at which the fans are triggered on GS66 are just really poorly distributed and I would like to modify those temps.
EDIT: Svet not sure yet.
xi.avatar6
I can send a donation your way if you think the GS66 wouldn't be too troublesome to get the EC-FW Tuner tool to support.
EDIT: Svet will check and add support for it
node
This looks like such an awesome tool, can you add support for the GE66 Raider? (10SGS)
farhanul154102dc
Need the EC FW tool for my recently purchased GS66, which is stuck at 2100 rpm even at idle! Its so loud. It was actually stuck at 2700 rpm before I downgraded the EC firmware but could really use your help to bring it down further when idle. I will be happy to donate. Can you help Svet? Thanks a bunch!! :)
EDIT: Svet check email FYI and queries.
OgUrecheK
Hello!
Can I use this tool to move the fan speed table from the old EC-FW version to the current one?
On version 107, the minimum fan speed is 2800 rpm, and on version 106, the minimum fan speed is 2000 rpm.
MSI GS65 8RE
EDIT Svet: For fan % change yes, if there is RPM changes too, then it won't be enough.
EDIT2 Svet: Has been solved plus additional manual private modification for rpm change too.
Sniffy
Donated Friday, thank you Svet for sending the tool so quickly. I would be happy to donate extra $$ for MSI GT76 Titan EC-FW support.
EDIT Svet: Check email/PM for queries about this GT76
