TERRIBLE ISSUES WITH MSI MOTHERBOARDS and Gaming PC's!!!
Radracer289155102d8
I have two gaming PC's now with MSI motherboards both are Pro X870-P Wifi models I believe but am sure one is. They both have new 5080 graphics cards and AMD 9800x3D CPU's so they should be running great/top of the line.
EVERYTHING motherboard related is COMPLETELY TRASHED. I have unexplained high latency with running latencymon on both PC's and am being told by technicians it's related to the motherboards having issues so I am not able to stream or record audio without major issues. This is with ALL the latest MSI drivers and BIOS version!!! Latencies up to 25 ms with multiple DLL's/drivers and latencies are NEVER supposed to exceed around .4 ms or so and should always remain well under 1 ms. Again, this has been traced to MSI motherboards!
Both PC's the fan control and RGB light control from MSI Center is TOTALLY SCREWED and randomly loses control of the fans and lights. It's been a total disaster building and purchasing 3 - 4k top of the line machines and MSI center can't even control the fans or RGB lights like any normal PC would. Can anyone from MSI help or do we all just need to stop buying MSI products if we want to game?
Can you share full system configuration and exact BIOS version and settings?
Did you enable EXPO or CPU OC related settings? Have you tried with default BIOS settings after clearing CMOS?
The MSI X870 Tomahawk has similar issues with 9800X3D and RTX5080. What helps with the Tomahawk ist the BIOS rev. 7E51v1A1A.
So maybe you should give rev. 7E47v1A25 for the X870-P a try. Something changed in the later revisions, that are problematic in combination with the RTX cards. I had no problems with the AMD 6800XT. But the day I installed my new RTX the chaos started.
