veysavorn202156802d8
- Oct 10, 2022
have you tried the JT1 shorting method mentioned above? what's your motherboard?
List your Full buildthe mainboard led firmware is abnormal... i try everithing
in system info say... LED FW Update(7B93), but verion installed is 00
screenshot atached
Please check PMin system info say... LED FW Update(7B93), but verion installed is 00
screenshot atached
Thanks for your help, but another problem.... error message in the msi led updater "connect to device Fail"Please check PM
Yep OK can you unplug any ARGB devices connected to the motherboardThanks for your help, but another problem.... error message in the msi led updater "connect to device Fail"
I follow the instructions: clear cmos, unplug power cord, turn off psu for 3 min, power on pc, close msi center, close all login apps, and run the upgrader.
screenshot atached
MSI may do a Global warranty RMA won't know till you ask them >>How to contact MSI.<<i try this but still with no motherboard or jrainbow rgb control... just a predefined rainbow breath
https://forum-en.msi.com/index.php?...e-–-msi-center-bug-status.362779/post-2066275https://forum-en.msi.com/index.php?...si-prestige-x570-creation.348421/post-2027500
im realy sad, my setup was green and black only... i read all related post on google and try everything i think...
i will try disconnect all argb and test, rma is not an option because i live in uruguay but i buy the motherboard in usa online... thanks again
i really apreciate your time trying to helpme... big hug from uruguayMSI may do a Global warranty RMA won't know till you ask them >>How to contact MSI.<<
Have you tried to unplug the ARGB cable from your PSU?PSU brand and model: THERMALTAKE Toughpower gf2 rgb 750w tt premium edition
Well at least they not started to put RGB on the CPU yet at least I know there is one part of a PC I can safely buy with no RGB on itHave you tried to unplug the ARGB cable from your PSU?
yes i try... but the same result, cant find device in led fw update tool.Have you tried to unplug the ARGB cable from your PSU?
ok, i will post results today after workWell at least they not started to put RGB on the CPU yet at least I know there is one part of a PC I can safely buy with no RGB on it![]()
