veysavorn202156802d8
- Oct 10, 2022
Here you are latest versionMB: MSI b650m project zero (Bios 7E09v1D)
Thank you very much but unfortunately connection to the device fail.Here you are latest version
https://www.dropbox.com/scl/fi/otic...ey=dvzipawgp9i31ikayni7n2mb9&st=gdw2sjg9&dl=0
Then your options are limited you will need to arrange a replacement under warranty or RMAThank you very much but unfortunately connection to the device fail.
yup. my build is 3 weeks old so am definitely under warranty. thank you for the assist!Then your options are limited you will need to arrange a replacement under warranty or RMA
>>How to contact MSI.<<
What message are you getting with the recovery toolI tried to re-install the firmware several times through the recovery tool with the right version for my motherboard but I didn't solve it, I also tried to drain the JT1
None, it will flash fw than suggest to reboot :/What message are you getting with the recovery tool
OK, I will get you to try an earlier version of the Firmware to see if that helps.None, it will flash fw than suggest to reboot :/
Oh quick question instead of ree-boot have you shut down and unplugged the PSU for 5 to 10 minutesNone, it will flash fw than suggest to reboot :/
EDIT:Oh quick question instead of ree-boot have you shut down and unplugged the PSU for 5 to 10 minutes
https://www.dropbox.com/scl/fi/qe9j...ey=xsohbi9rw9szaooucpmxuf6fp&st=j7nf1igq&dl=0It's possible to request the v3 fw?
Unfortunately I keep having the same problem, no program can change the colour of that block.
OK I would say you have a hardware fault and will need to RMA the boardUnfortunately I keep having the same problem, no program can change the colour of that block.
Well, after looking againMy rgb header wont work.
HerePlease get me 7D13_v0004 if possible i can see only the 7D13_v0005 on the website.
Thanks worked fine.
The ARGB headers or ARGB controller could be faulty if nothing works with themThanks worked fine.
Is it possible that my RGB is bricked? I am unable to enable it no matter if physical switch on my b550 unify-x is on or off its still not showing. The only rgb thats working is my ram that i can enable or disable via software no matter if the physical switch is on or off.
