The monitor turns off 3060 VENTUS 2X 12G OC
pupsss7152202da
The monitor turns off, but the system is working.I noticed that after reinstalling Windows, such a problem appeared
Motherboard:ASUS PRIME B250M-PLUS
Bios Version:1205
Video Card:NVIDIA GeForce RTX 3060 (GA104) [MSI]
PSU brand and model:aerocool vx plus 750w. 750Bt
CPU:Intel Core i7-7700
RAM: Corsair Vengeance LPX [CMK8GX4M1A2400C16] 2x8 ГБ
Storage SSD&HDD: SSD kingston hyperx savage shss37a/480g , HDD caviar blue wd10ezex 1tb
CPU Cooler: Deepcool gammaxx 300 120mm ret
OC: (Yes / No) no
Operating System:Microsoft Windows 10 Home (x64) Build 19045.2311
pupsss7152202da
Monitor turns off when/while doing what?
When I log in to the game, At the same time, I turned on furmark and everything worked.
How do you know that's working?
There is a sound, and you can hear the partners in the discord
When this issue started? Does it worked fine before?
After a clean install of Windows ,yes
pupsss7152202da
Монитор выключается, когда / во время выполнения чего?
with and without load
Откуда вы знаете, что это работает?
Когда возникла эта проблема? Раньше это нормально работало?
At the same time, when I connect my old 1050 ti, but there are no such problems.
Administrator
Can you borrow a better PSU to try?
Or this new GPU in another PC [who has a better and quality PSU]
pupsss7152202da
Или этот новый графический процессор на другом ПК [у кого есть более качественный блок питания]
Tomorrow I will take the video card to the computer service center for diagnostics. To make sure it works correctly.
Administrator
Okay, let me know how it goes.
pupsss7152202da
Administrator
Do you use latest Nvidia drivers? 527.56
What OS exactly you are running?
