fr.simon.robert.broughto156102d9
- May 2, 2022
Hi, I've been patiently waiting for MSI Technical to sort my problem out with a "ticket" but I'm sure someone here has come across the very same problem as I have.
Tomahawk B550 motherboard has GPU built-in but my Ryzen 5900x Chip doesn't have the capability to talk to my onboard GPU.
I knew this to be the case. They're listed as compatible but I need to use an external PCI-e graphics card. No problem.
I pulled out a fully working RX580 ARMOR 8GB OC graphics card and fitted it in the PCI-e slot. Added the extra power cables to the graphics card.
PC boots up. It goes through the process but continues to stop with the LED for the GPU problem.
How do I get into the Bios as my keyboard only comes alive when it stops at the LED for GPU. I've held down the "delete" button but it does nothing at all. I've tried ESC and F1 all the way through to F12. Can anyone help? Is there any way for me to get into the Bios and turn the onboard GPU off?
System configure:
1. MSI MAG B550 TOMAHAWK Motherboard ATX, AM4, DDR4, Dual M.2, LAN, USB 3.2 Gen2, Front Type-C,
Mystic Light RGB, HDMI, DisplayPort, AMD Ryzen 5000 Series
2. Patriot Viper Elite II DDR4 128GB(4 x 32GB) 3600MHz
3. RYZEN 9 5900X PROCESSOR.
4. 512GB M.2 MEMORY (for Slot 1)
5. 512 M.2 MEMORY (for Slot 2)
6. 1TB SSD hard drive SanDisk
7. DEEPCOOL GAMMAXX GT BK, CPU Air Cooler, SYNC RGB Fan 4 Heatpipes, 120mm RGB Fan,
8. Safekom Silicone Heat Sink Thermal CPU Processor Compound PC Grease Paste
9. Aerocool Integrator 850 W 80 Plus Bronze Power Supply Unit with UK 3 Pin Power Lead
10. MSI MAG VAMPIRIC 010 Mid Tower Gaming Computer Case 'Black, 1x 120mm ARGB Fan, RGB Front Panel,
Tempered Glass, MSI Center, ATX, mATX, mini-ITX'
System configure:
