top PCIE running x8
MegaGoat
That both sides of the pcb contacts ? And yes that might be your problem there its looks like physical dmg
badboy2k
if they are where i think they are on the connector on the side i think that goes through 2 Signal Out pins and 2 Ground Pins on the connector and that would cause your Motherboard to Ignore the last 8 lanes.
from where it is that is going across the return Digital Signal pins for PCI-E lane 14 and if its on the other its right across the Input pins of Lane 14 instead and either of them 2 would auto limit it to 8 lanes
that would explain it.
badboy2k
here is a Image of the pins that mark is across
Blue = Input
Pink = Output
and its across them 4 pins either on side A or B
badboy2k
is that on the upper side of the connector? which is on the side the Main Boards CPU is?
