Trident 3 won't turn on.
pajfishe156102e2
Hi I have a barely used nearly 3 year old trident 3 pc, the power supply seems fine and is giving out 19 volts but the pc shows no signs of power at all, I've checked the motherboard and nothing seems blown.
Any ideas at all why this may be the case.
Paul.
fauc
Active member
SECOND LIEUTENANT
1.The LED is on or off on chassis.
2.This Trident 3 system is with extra graphic card or not.
3.Please provide brand and model for monitor.
4.What port is connected cable on Trident 3? Example: HDMI or DP
5.What port is connected cable on monitor? Example: HDMI or DP
Note: Don't use any adapter. Example: VGA to HDMI.
pajfishe156102e2
Nothing powers up at all, the red led on the motherboard does not light up, no fans spin etc.. I've 19.5v at the power brick and 19.5v on the board but nothing at all. I have removed and replaced the backup battery with a new one but nothing seems to work, I've scanned over the motherboard to look for dry joints, blown caps etc but it looks perfect, I've literally used this for no more than 20hrs in 2 1/2 years and came to use it yesterday to just update the OS and it just didn't switch on.. 🥺
