tv anywhere master can not work on my pc now
mohawk7507
I have a problem with the tv anywhere master.
a few years ago when it was new everything is functioning normally. no problem.
because it had long been unused tv tuner so I save.
when there is a need to use the tv tuner on my computer then put it back.
the problem now:
at the turn msipvs always error. can not sign in to the application
what are the new drivers or software for tv anywhere master?
My computer spec:
Pentium D 805
Gigabyte P965 S3
ATI 4650 DDR3
os
windows xp sp3 32 bit
windows 7 32 bit
please help to all the moderators or the technical support of the members of the forum tv tuner to solve this problem.
Thank you for your attention
rhradacut
Active member
GENERAL OF THE ARMY
There are no new drivers for that old card only drivers from MSI for it are here:
http://www.msi.com/product/mm/TV-nywhere-Master.html#/?div=Driver&os=XP%2032
Keep in mind that even if you can get it working it will only work connected to a cable system, it will not work for over air digital TV broadcasts.
What country are you in?
