tv@nywhere channel changes, video yes, sound no!?
M
mentalspew
Guest
hey there-
i just installed the msi tv tuner card in my machine (shuttle ss51g /
windows xp - NOT sp1)
everything seems to work ok expect for the following:
when i..
1. change channel (either manually using the keyboard or the remote
control)
2. the channel changes and video is displayed
3. however, there's no sound!
what's going on here?
the only way i can get the sound back is to pause, then play the live
stream. but, this is only a workaround..
any ideas?
thanks!
dave
B
BlueF
Guest
Funny, I have the same setup, a Shuttle SSG51. Also, I had the same problem, I was losing sound when I changed channels. Good news, I did find a "fix".
Under SETUP --> TV -- > Audio Mode = "Manual Selection" and for Stereo Broadcast = Mono.
Hope this helps.
L
lunat1k
Guest
Also experienced this problem and can validate the workaround. Hmmm.
