Ive got an issue with using my remote to control Hypermedia Center. The remote doesn't work with the Hypermedia software and there seems to be no option to change it to work.
Installed my TV @nywhere plus without issue. Installed the drivers and software with the included CD. The standard software from the CD worked fine, detected video and audio. Remote works with that version of the software.
However the software from the CD doesnt zoom correctly, stretching the video image to widescreen proportions when its 4:3 tv signal.
Searching online found the Hypermedia software on MSI website, this software also works for the video and audio, and zooms in the correct aspect.
Problem is the remote doesnt work with Hypermedia. Theres no option in the remote software to change it to control the Hypermedia software. Remote still works, pressing power launches the original software from the disc.
How do I get this remote to work with Hypermedia Center?
Drivers from the website and software from the website already installed.
Windows XP
Windows XP
