TV @nywhere plus in a small form factor PC
ortingwing
I have just moved my TV @nywhere plus card from an old tower to a slightly less old HP small form factor PC.  This PC requires low profile cards.  The TV @nywhere card fits fine and it seems to work in the Win 7 machine too, as long as I leave the cover off.  But the bracket won't fit in this case. Before I start butchering the bracket, does anyone know if there is a low profile mounting bracket available that will fit this card?
rhradacut
Active member
GENERAL OF THE ARMY
Not that I've seen anywhere. You (or perhaps someone you know do it for you) would probably need to modify the existing bracket to fit. Carefully cut, bend & file a screw slot.
