TV@nywhere Pro / Analog, how can i change the standard capture port?
Cuxman
i want to get a video signal over directX and this works,
but always i have to change the capture port from s-video to composide-in manually.
Can i save the composite-in as default port, in the registry or somewhere else?
I don't want to install the large TV softaware to use the card, so please don't refer to it.
Thx for any Help.
Stu
GENERAL OF THE ARMY
What program are you using then? :think:
Cuxman
Its a medical program that no one here will know,
it has a standard directX interface that asks the card for the port.
So is it possible to change the first capture port?
Stu
GENERAL OF THE ARMY
The choice of capture port is down to the software using it, so you'd need to contact the developers of your software for support with this.
