TV@nywhere Remote
L
lunat1k
Guest
Has anyone else had problems getting the TV@nywhere remote to work?
-IR sensor is plugged in and in line-of-sight.
-Battery is in w/ correct polarity
-Paper tab was pulled out
-Software is started.
I didn't see any place to configure or test the remote.
Fam
STAFF SERGEANT
i had the same problem with my first card. i got my second card to work with these drivers as it didn't like the current set of msi drivers. try them and let me know if they work for you.
J
JCJames4
Guest
The remote will not work if you have Windows XP with SP1. Works fine without SP1 installed.
K
kashmeer
Guest
Until they come out with a new set of drivers the remote will not work with SP1. Once SP1 is installed the only thing you can do is to install from scratch. Uninstalling SP1 from the control panel does not help.
