Hi!
I posted this error in german also but get no answer. I will try it in english!
You have to use the driver version 1.1.1.800 to be able to work basically with MCE. For the first time you can do everything with this card but you have to keep away from the stop-bottom in MCE! If you stop the playing of any channel you can't start again! Any! The error message is something like "no signal from the card... channel temporary not available...".
If stop MCE (Windows Media Center) and start the DigitalTV (Version 3.4 build21) you see an error! After you press the OK bottom the DigitalTV screen appears but you see nothing it's just blank!
The trick is to start DigitalTV in admin modus! If you do so everything in DigitalTV works fine! I'm not able to start MCE in admin modus. Perhaps this can solve this problem?
Who is able to help me!? And a lot of other person with the same problem!
The second thing is: I need a low profile bracket for this card! Where can I buy this little thing?
Thanks,
Darius
Thanks,
Darius
