Unable to power Big Bang XPower motherboard
Hard2hit83
CORPORAL
I don't post on boards much.  I'm relatively inexperienced, this is the second time I've assembled a computer.
Everything appears to be installed properly, but I cannot get any of it to power up.  Only evidence of current is the blue touch power button/OC genie will light up when depressed
My components:
Corsair 750W PSU
MSI Big Bang XPower Mainboard
i7 930 processor
XFX Radeon HD 5850 GPU
3x 2GB Corsair DDR3 Dominator RAM
Thanks very much for any assistance.
Otherwise, can you recommend any chains that might be willing to look over my hardware?
No.  I live in Germany.  Check the phone book and the yellow pages for your area.  Then call & ask if and how they can assist you and how much it will cost.
What about this:
You could try this:  http://lichyetan.blogspot.com/2009/03/how-to-jump-start-atx-power-supply-unit.html
Do that before going out to buy a new PSU.
Specifically for the Corsair power supplies:  (which was how I tested mine before the motherboard arrived...)
http://www.youtube.com/watch?v=5FWXgQSokF4
It was a faulty power supply.  Went and bought another one and my mainboard lit up like a Christmas tree.  Hard to believe that a 140 dollar power supply could arrive DOA like that.
Hopefully I'll at least get to setting up BIOS tonight.
Thanks for your help, guys.
And in a new and surprising turn of events, after I installed the components in my case in the exact same configuration they were working in outside of the case (including my beautiful new power supply), they wouldn't work.  I removed all of the components and attempted to reproduce my previously powered board.  No luck.
Is it possible for me to screw up a PSU just by installing it in the case?  I used four, inch-long docking screws that were provided with the case.  Could they have dislodged something when I installed it?
Sounds like a short circuit.  Take the board out againa and check the stand-offs between case and mainboard.
You mean attaching the PSU to the case using 1 inch long screws? Screws shouldn't need to penetrate more than a few threads into the PSU mount holes.
