Unable to use the bluetooth and wifi functionality of my wifi capable motherboard.
equality2k154402d6
I recently got an MSI b550m pro vdh wifi board on my pc. After setting up the pc and installing windows, i installed the necessary drivers as usual. However, i noticed that after everything, i still cannot connect via bluetooth. when checking device manager, it says that i have driver errors with my bluetooth and wifi drivers. I reinstalled the drivers, switched the antennas around, and everything, but i still get the driver error and am still unable to use the bluetooth and wifi functionality on my pc. any help?
ronnierichard
SECOND LIEUTENANT
  • Quick hack to possibly kick them into gear @equality2k154402d6
  • 1. Turn off the PC.
    2. Unplug power cable to PSU.
  • 3. Hold power button for 30 seconds.
  • 4. Plug power back into PSU.
  • 5. Boot PC.
Alan J T
Wifi Driver here
Blue Tooth Drivers here
AMD Chipset Drivers here
>>AMD Drivers<<
ronnierichard
SECOND LIEUTENANT
Did you figure it out? same issue with my B550m a pro-vdh wifi mobo
Did you DL the chipset drivers and drivers for Bluetooth and wifi? You may need to do it from a friends PC to a USB stick, but Windows should plug in a generic driver for you to at least get online once you restart a few times (like full shut down, power on, not menu restarts)
