- Feb 18, 2018
Sent you a PM!Yo Drek, I'm about to get an MSI Stealth 15 A13VF. Can you hook me up with the details?
Have fun with your Stealth 15 A13VF!
Sent you a PM!Hello! Can you help me too?
MSI Creator Z16 A12UET
Sent you a PM!Can you help me with it? Thanks!
MSI Creator Z16P B12UHST (Specs: i7-12700H, RTX 3080)
Hello! Can you help me too? MSI Creator Z16 A11UET, Intel Core i7-11800H, RTX 3060Sent you a PM!
Sent you a PM!Sent you a PM!
YesMS in Windows 11 has disabled undervolting for 12th and 13th Gen CPUs, with the help of Intel.
Their is a Bypass in the BIOS to achieve a similar result, if you feel comfortable changing the settings in your BIOS, I will send you a PM with the info.
Just reply to this message by saying yes and I will send.
Advanced BIOS = Hold LEFT-ALT + RIGHT-CTRL + RIGHT-SHIFT, then press F2
Sent you a PM!
Sent you a PM!Hello, can you help me too ? I have a MSI vector gp78 hx13v
Sent you a PM!Hi drek4! was hoping you could help me too! thanks, Ed.
- MSI Creator Z16 HX A13VF (13980hx CPU)
YesОтправил вам личное сообщение!
Try to post in English mostly, the moderator can kick you, if you don't comply.Здравствуйте, можете ли вы мне тоже помочь?
msi катана b12vfk-463xru (i5 12450h)
Sent you a PM!Здравствуйте, можете ли вы мне тоже помочь?
Sent you a PM!Hi! Can you help me too?
MSI Creator M16 B13VE
Can I have it please as well?Sent you a PM!
Use the same as i7 12th Gen, for your i5.
Sent you a PM!Can I have it please as well?
