damned200156a02d3
- Dec 17, 2024
Please, need your instructions in PM (Creator Z16). Thanx in advanceMS in Windows 11 has disabled undervolting for 12th and 13th Gen CPUs, with the help of Intel.
Their is a Bypass in the BIOS to achieve a similar result, if you feel comfortable changing the settings in your BIOS, I will send you a PM with the info.
Just reply to this message by saying yes and I will send.
Advanced BIOS = Hold LEFT-ALT + RIGHT-CTRL + RIGHT-SHIFT, then press F2
