- Dec 28, 2013
Hey folks,
I hope you are all well.
I'm really not sure where to start with this - I've been an overclocker for a number of years but I'm new to undervolting so I'm really after a starter-for-ten. In every overclocking case I can remember (other than the obvious pushing too far and crashing!), it always resulted in a net positive performance improvement.
However, since upgrading my 8700k and dipping my toes in with an 5800X3D and then recently changing to a 13600k/MSI Z690 Gaming Edge WiFi DDR4 recently I've understood that these CPUs turn the traditional equation upside down. They are generally already tuned for near maximum performance and temperature limits throttle clocks down to prevent the system from crashing.
As it seems overclocking has very little improvement with these CPUs, it seems that going the other way, undervolting (to get the same performance but for less power / heat expenditure) is the way to go.
With some initial investigation I've been successful in bringing down the power consumption and heat but I've been finding it has been at the expense of input lag (something I am very sensitive to and a real #1 bugbear of mine).
The figures are too tempting to simply ignore, however. I was monitoring a match on Battlefield 2042 last night, when the 13600k was on 'auto' on CPU lite load (which I think was Lite Load level 12) and it was pulling around 150w. When changing to CPU Lite Load level 3, this came down to approximately 95w.
Temperatures followed a similar positive result, dropping from around 80oC to mid 60's. In synthetic tests / stress tests (e.g. Prime95), I noticed this was the difference between the CPU throttling to keeping below 90oC and no throttling occurring on
However, I cannot ignore the fact that in both the case of the 5800X3D (undervolted with a simple vcore offset voltage) and the 13600k (reducing CPU Lite Load to level 3), however, there was a tangible loss of 'smoothness' and mouse responsiveness felt more laboured and sluggish.
To ensure it wasn't placebo, I even went to the extremes of setting up a standard test in CS:GO (the waiting room of the fps test level), a 1000fps camera and 'reactive' light on my Razer viper mouse to count the frames difference (not an ideal test but gives something to go off - generally the muzzle flash appears on screen before the mouse light activates).
My notes are a bit scrappy (and I'm missing the 13600k stock tests) but included I've included below for completeness.
The TL
R version - the more aggressive the undervolt, the more input lag presents itself. In addition, the stronger the undervolt, the more inconsistent the results were (i.e. a much greater mix of the muzzle flash either appearing before or after the mouse light.
Finally, also worth mentioning (noting the lack of 13600k stock result currently) is neither system has been quite as responsive as my 8700k @ 5ghz was input lag wise.
5800x3d Stock:
Muzzle flash appears...
- 1 frame before light
- 26 frames before light
- 16 frames before light
- 38 frames before light
- 8 frames before light
+ 6 frames AFTER light
- 10 frames before light
- 22 frames before light
Total = 157 frames before light
Average = 15.7 frames before light
-0.200v offset + Kombo Strike 3:
Muzzle flash appears....
- 35 frames before light
- 11 frames before light
+ 12 frames AFTER light
- 3 frames before light
- 9 frames before light
- 31 frames before light
- 34 frames before light
+ 15 frames AFTER light
- 18 frames before light
+ 18 frames AFTER light
Total = 96 frames before light
Average = 9.6 frames before light
15.7 frames (stock) - 9.6 = 6.1
TOTAL EXTRA LAG = +6.1ms (slower)
-0.100v offset + Kombo Strike 3:
- 5 frames before light
- 7 frames before light
+ 2 frames AFTER light
- 4 frames before light
- 2 frames before light
Total = 43 frames before light
Average = 4.3 frames before light
15.7 frames (stock) - 4.3 = 11.4
TOTAL EXTRA LAG = +11.4ms (slower)
8700k reference tests
- 6 frames before light
- 29 frames before light
- 36 frames before light
- 13 frames before light
- 42 frames before light
- 24 frames before light
- 39 frames before light
Total = 242 frames before light
Average = 24.2 frames before light
15.7 (5800x3d) - 24.2 frames = 8.5 ms faster
TOTAL EXTRA LAG = -8.5ms (faster)
13600k - Mode3
+ 4 frames AFTER light
+ 10 frames AFTER light
+ 3 frames AFTER light
- 15 frames before light
Total = 136 frames before light
Average = 13.6 frames before light
15.7 (5800x3d) - 13.6 = +2.6ms (slower)
TOTAL EXTRA LAG = +2.6ms (slower)
The TL
5800x3d Stock:
13600k - Mode3
