ajaguck152b02d6
- Nov 12, 2020
When I enable the Memory XMP Profile 1 to get DDR-3600 speeds, the system becomes unstable exhibited by unexpected hard reboots.
It has occurred under load and when idle.
Additionally, in the Windows Event Viewer, many WHEA-Logger warning events are generated when XMP is enabled. See inside attached file for warning details. (Event ID 19)
After the hard reboot I can also see a few WHEA-Logger errors as well. (Event ID 18)
However, if I disable the XMP profile, I do not see any WHEA-Logger warnings nor errors in the Windows Events viewer. I have not witnessed any unexpected reboots with XMP disabled yet.
Of course, I would like to use the XMP profiles for full system performance with the Ryzen 5950X CPU.
I submitted a ticket to MSI about it, but wanted to report here for others if they encounter this issue.
I'd like to know if others are experiencing this as well.
Thanks in advance for your support and discussion.
BIOS ver: 7C94v14
BIOS ver: 7C94v14
