(Updated:2016/05/06)"Silent Option" Fan Control Application for MSI Laptops
Status
Not open for further replies.
Some of you tried it on the MSI GS40 6QE Phantom?
Should work with the named CPU, but I want to ask before I buy.
To much money for an annoying fan.
Thanks a lot!
This works easily on the GS60 2QE (4K), i was seriously already trying to sell the laptop.
I was unable to use the laptop at libraries, now everything is as quite as it should be when surfing and using word.
With some simple settings on the change advance energy settings in windows power settings, my on-battery-life also improved dramatically.
I put fans to 0 unless the cpu/gpu reaches 60?C so this is quiet ALL the time.
Great, great app!
Some go for svets-tuner but for fan-noise this program is just perfect!  ;)
Hey guys,
I installed your software on my GE 72 6QF with Windows 10 and all Drivers up-to-date (Skylake), because for obvious reasons. Good idea, simple program, but I am unable to adjust the CPU fan speed by using the "Basic"-option or "Advanced". I can just decide between turn the fan off (0%) or having it on 3333 rpm (1-60%). I thought with this little program I'd be able to adjust the fan up to around 1500 rpm, so it's not off but turning way slower than before. It's installed as advised, hope for help!
Hi t.eismann.au,
No, it can?t. The fan needs minimum voltage for starting. Therefore, you will 3xxx rpm when fan starts running.
Hi all !
I bought Svets Tuner as soon as I got my GS60 because the fan problem was just too much and I only see now that there is an MSI tool for this ! Is it efficient ? Can I use it in combination with the Svets Tuner installed ?
I don't know why but the fan is now on at low speed even when the computer is idle and I wonder is maybe it's because of the dust settling after a year of use...
Same issue. I have GP62 6QF. my laptop isn't on the list of supported models. please MSI team. help me.
thank you in advance.
How to make this SilentOptions profile auto start on windows start up. Mine start only after pressing the save button at  Advanced Tab for every time log on to the windows, the profile has been set up already though. :embarassed:
Where do you set in software? Could you post a picture for your settings?
Besides, what kind of notebook do you have?
You could try to use latest Help Desk to export the system info and post the text information in here.
[attachthumb=1]
Thank for your reply !!!
I have attached my MSI information above. I'm using Silent Option ver 1.0.1603.3001 for Haswell, SCM installed.
The configuration :
  • GE62_2QE(20170324).txt
Status
