UPDATING BIOS HELP
I BOUGHT INTEL i5 -9400F PROCESSOR AND MOTHERBOARD H310M-PRO-VH-PLUS
ON THE BOX OF MOTHERBOARD IT SAYS IT SUPPORTS INTEL 8TH GEN. BUT IN OFFICIAL SPECIFICATION ITS WRITTEN THAT THIS MOTHERBOARD SUPPORTS 9TH GEN INTEL PROCESSORS TOO .
I AM BUILDING NEW PC , I WANT TO KNOW ,
1. CAN I INSTALL i5 PROCESSOR , RAM AND OTHER THINGS BEFORE UPDATING BIOS ? I WILL INSTALL WINDOWS 10 FIRST THEN CAN I UPDATE BIOS ?WILL IT WORK ?
2. CAN I INSTALL i5 PROCESSOR , RAM AND THEN UPDATE BIOS BY M-FLASH WITHOUT INSTALLING WINDOWS.
OR
I HAVE AN OLD INTEL i3 2ND GEN PROCESSOR , CAN I USE IT IN THIS MOTHERBOARD THEN UPDATE BIOS , THEN INSTALL i5 IN IT?
please help me
my email - pravin.mathanker@gmail.com
my whatsapp- +918989517159
Administrator
Please do not use caps all the time.
You can see supported CPUs here:
you can't update the BIOS without CPU or RAM
you need a working computer to able to update the BIOS
yes or better update it before OS install
yes, you can
2nd gen means 2xxx series? if so no.
check the supported CPUs from the link that I sent you above.
however the board probably should be able to boot with i5 -9400F, check the QVL list
thanks Svet for this help .
i wanna know one thing more " can i update bios after installing processor and ram only? does it require any hard disk ?
yes, you can
Administrator
As long the computer can boot yes you can, no need any storage.[besides the usb key to flash the bios from it]
@Svet i not tried to install processor in motherboard yet . i am waiting for my other products.
i am worrying about " will my system boot or not after installing i5 processor and ram " ?
if it not works then what options do i have ?
please help
