tristonwhite2152e02d5
- May 20, 2024
i appreciate the reply, in response to this, i did take precautions and did the research prior to opening up the computer, i understood the risk of shorting the motherboard and components, i was performing the repair with care to not damage anything. The only reason im saying i assumed i didnt need to remove the battery is because i was informed that i didnt need to remove the battery to upgrade the ram and the SSD on the device and since the fan was only one small connector i thought it would be an easy plug and play solution, which i can see how it isnt ideal. The thermal paste isn’t ideal but i was lacking the funds to rebuy thermal paste so i believed using the preexisting thermal paste would work. I understand assuming is bad, i am new to these things and i still need to improve on my skills and preparation. I am interested in getting better at these things but have lacked much of the experience and teaching required, which caused me to try a hands on approach to all the technology i’ve worked on, with success all the way until today.Of course, but ripping open a laptop wrecklessly without taking care of googling, watching videos about your laptop for references and insuring to have knowledge prior to doing this.
I would never, ever, ever, remove a fan heatsink without having at hand the proper paste or thermal component to adequately repaste it.
You did every thing the wrong way, could be numerous things, slight scrap of your screwdriver, a screw that fell on the motherboard,
the heatsink touching a component on the motherboard, etc.
Do not assume, when you assume, you make an a s s out of u and me
If you shorted the motherboard, there is no fixing that, new motherboard or new laptop, the latter would be the better option.
Well if it is so important, show it the proper care and respect next time!
