My way (and I think I can speak for most of the others also) to get this experience is history. No longer possible. Times change, technology changes, the way how we learn has changed.
The Linux way has also changed. We are no longer compile our own Kernels, no longer dive in make files to find this bracket which is on the wrong line.
We still edit configuration files but this is not the same.
To learn more about Linux the Arch Linux Wiki is one of the best resources. At some point to install a Arch Linux even if it is in a virtual machine ...
But I don't like the attitude of the Arch People ( I use Arch btw ). F**k these people and their pride. That I don't use Arch means not that I am unable to install and to use it.
Even the Arch way has started to change, they have now a "Arch Install Script".
I use Manjaro btw.
I am not a member in the Manjaro forum but I follow it. Friendly and helpful people if you follow the forum rules.
Edit:
If you use a Rolling Release (and Manjaro is a Rolling Release) then it is a good idea to look in the forum before you do a bigger update. Makes things much easier when you know about possible problems.
