USB 2.0 port not working on Katana GF66 11UG
moehl15a502de
Hi - I have a new Katana GF66 11UG. The USB 2.0 port doesn't seem to work. No devices are recognised if I plug anything into it. In Windows device manager, I can only see two USB controllers (the USB 3.0 ports, which both work). In the BIOS, I also only see 2 USB controllers listed.
Is something wrong with the USB 2.0 port? Is there a software fix for this?
Windows 11. Fully updated including drivers. USB power management options turned off in device manager.
Crazydonkey
SECOND LIEUTENANT
Try to reset EC first. If the problem still persists, send back the laptop for repair.
Did you use the USB flash drive to check?
Some of devices require the specific function to run. Maybe the USB port does not support it.
