USB-C port problem MSI Summit E15
conrad155002e2
I have an MSI Summit E15 laptop connected to an MSI USB-C dock.. I have been using this setup from inception however over the last few months every now and then when I plug my laptop back into the dock and turn it on the dock powers off... Yesterday when connected it to the dock the same thing happened and when I powered on the dock I got an error message that windows did not recognize the USB device and it would only allow power delivery, network connection and monitor output. None of the USB-A ports would work. I tried a few times to restart my computer and the dock with no success. I then plugged the dock into the second USB-C port on the computer and everything started working again. Does this mean that I have a faulty USB-C port? There are no driver errors in Device manager when the dock is unplugged or when plugged into the second USB-C port but shows errors when plugged into the first port.
drek4
Active member
PRIVATE FIRST CLASS
Did you try other devices in the port to know if the culprit is the port or the dock?
