USB keeps randomly disconnecting for G.I Ai 1300P PSU
Kesh
I've had this problem since I bought the PSU but up until recently, I just can't get the USB to stay connected anymore. It will just disconnect and throw up a Code 43 error. Do I need a BIOS update or a new USB cable?
Which mainboard you use?
Can you double check the USB cable? Make detailed pics of the connectors? Check for loose wire.
