Usb led option missing in dragon center
dharani123dharan
After factory data reset usb led option is missing. I need (C:\Program Files (x86)\MSI\Dragon Center\Sendevsvc) file from another lap with usb light enabled. This will fix my problem
Crazydonkey
Active member
SECOND LIEUTENANT
Did you bring your laptop to their service center?
Sometimes the online support won't help.
tirosal158002e8
I installed this driver and it worked. It was the original driver that have the usb led support
If link dont work i searched for ge63 raider drivers on google, opened the softpedia website and downloaded the dragon center utlity 2.1.1804.1102.
Uninstalled the dragoncenter that i have, and next installed the one of softpedia, now works fine.
Hope that it help you
dharani123dharan
it only supports 8 th gen inly sad.
dharani123dharan
can you archieve and send installation files from your pc???
and
C:\ProgramData\MSI
