siftullah0153302d4
- Jun 21, 2025
I recently purchased the MSI Vanguard 5070 SOC. Performance is fine with no issues. However, the front RGB (marked with red lines) does not light up. I've had the GPU for three weeks and have only seen the front RGB light up once and even then, it was stuck on orange and not controllable via Mystic Light. The upper and side RGB zones work normally and are fully controllable. Has anyone else faced this issue and found a solution?
