vbios request for 2080 Duke OC
ghostertaker
im wondering about an very loud card, if the card temperature hit 78 degrees the fan speed set automatically on 100%. The tempaturelimit(powerlimit) is set at 85 degrees.
Im using the bios "NV372MH.125"
S/N1: 602-V372-34SB1809001150
Best regards,
Tobias
Active member
Administrator
The card has some kind of thermal issue,
it need to re-pasted and cooler/heat-sink re-seated & thermal pads to be checked.
Check about this with your reseller and nearest MSI office if they allow you to do this at your place,
or if you will need to send the card to be fixed.
