Ventus 4070 x3 looking for fan header current specs, want to run dual 120mm chassis fans
ftrv201156d02dd
SFF build with 280mm AIO, bought cables to plug two chassis fans into the two stock GPU fan headers(no additional headers on this GPU, shroud and stock fans removed to allow room to run the bigger fans. Working pretty well but I want to control the fans with the GPU instead of the MB as cannot get the Fan Control app to recognize the MB fan headers so not able to set it up that way.
Also I prefer not to run a fan hub as keeping cabling and parts to a minimum for better air flow, less clutter.
I am using Arctic BioniX P120 fans to cool the GPU, they are mounted above the up facing GPU and facing it, blowing air out the top of the case.
Those fans draw .13 amps each, two Arctic fans, two headers on GPU(one header runs two fans on GPU, second header runs one fan)
I need to know if the GPU headers can handle .13 amps or if not what they can handle as I can turn down the RPM as so far it seems I really do not need full speed.
System:
Lian Li A4-H20 case
Z690 M-ITX MB
i5-13600k
280mm AIO
Ventus 4070 x3 GPU
Thanks!
Rick
System:
Lian Li A4-H20 case
Z690 M-ITX MB
i5-13600k
280mm AIO
Ventus 4070 x3 GPU
Thanks!
Rick
typically all fan headers even on a GPU are linked to a 1A Current Source as its generic so should be 1A
Thanks, I am looking at several places to ensure I have this correct and all seem to think this will be no issue at all and I have them set to 80% max and they have not needed to spin beyond much less than that so maybe drawing .08 amps at the most....I have an amp meter but it will not measure such low current values.
