J
jimmitch
Guest
I am having a very odd problem with a new installation of a K8TMaster2-Far board. The fault is that after 5 to 10 minutes, the machine goes into what looks to be a 'standby' or 'hibernation' mode with the fans off, screen blank, and the power LED blinking at about a 2 second interval.
An Infrared thermal probe of the CPU's says that the heat sinks are at 89 degrees Farenheit, the Northbridge at 91 degrees F, the memory at 86 degrees F, and the regulators at about 92-101 degrees F. Ambient temperature is 72 degrees F
This is really quite frustrating, since there is no apparent recovery short of using the AC switch on the power supply to hard reset the machine, which then 'wakes up' in a locked condition with the fans on high, the drive lights all on, and no display or apparent keyboard input.
I have simplified my setup to the following:
MSI K8TMaster2-far (on bench)
512Mb PC2700 Apacer memory (registered) in slot 1
1 Opteron 240 CPU (from known good machine)
Enermax 450W power supply (new, replacement)
1 Maxtor 150Gb SATA drive
Nvidia Ti4200 AGP card
I have gone through the CMOS settings serveral times and am confident that 'suspend' and power-save modes are disabled, re-flashed the BIOS to the latest version, performed a 'restore optimised defaults' from CMOS (this should re-write NVRAM, shouldn't it?) and have reset CMOS with the jumper.
This machine exactly duplicates another server which I've built, and that machine has run flawlessly for almost a month now, which is what I expect, since all of the parts are on MSI's 'approved' list.
I am now out of ideas since the problem prevents me from even loading Windows Server 2000.
Any suggestions?
TIA
Jim
Any suggestions?
TIA
Jim
