Vigor GK80 RGB stuck in bootloader mode
MrJackG
Hello, I was updating the firmware to my Vigor GK80 keyboard and the download failed and now the keyboard wont work. I used Dragon Center to do it and the keyboard wont recognise anymore. Can anyone suggest a solution to revive my keyboard?
You can only rma the keyboard as it is bricked.
MrJackG
Nah I got it fixed... Dragon Centre bricked it. I used Gaming Centre to fix. There was a .bat file for my keyboard that worked in flashing the firmware.
alipourarmi151402d6
Hi
I have gk70 and my keyboard doesn’t work and scroll lock and caps lock was blinking!
Yesterday i want to upgrade it but doesn’t finish .
Can you help me ?
m.a.naffakh158c02ec
Hi MrJackG
So thankfull for your solution :beerchug: , I have the Vigor GK70 .. its typing fine but the LED Lights stoped working ... after executing the GKLEDController.bat file the problem is now solved
THANK YOU
