Wake issues on B550-A PRO
karlshea
I have a new build with B550-A PRO, which is replacing an Asus board where all of this just worked, so I'm hoping there's a solution:
I'd like to 1) wake the computer up by hitting a key on the keyboard, 2) wake the computer with a WoL packet, and 3) let Windows wake the computer itself (for backups, using its task scheduler).
It seems like the current BIOS is unable to do this. The two options for "Wake Up Event By" are:
  • "OS": Windows can wake the computer up itself, but keyboard/NIC won't (have to hit the power button).
  • "BIOS": Keyboard/NIC can wake computer, Windows can't.
It doesn't seem right that both can't work at the same time in 2021, especially since an Asus board from 2016 was doing it, but I'm hoping I'm just missing something?
hookerja156c02e4
Active member
I feel ya! I have the B550 version of this board and wish the BIOS had a "Power On By Mouse/Keyboard" option along with better wake options ...
As it stands, when I go to bed, I lock the PC down and turn off my wireless mouse. Monitor goes blank after 1 minute.
Nothing should wake my system after that, but about an hour later, my monitor will come on for seemingly no reason at all ...
Alan J T
Yep compared to intel systems the AMD wake functions really need a lot of work
karlshea
Is this an AMD issue or an MSI issue? I would not have bought this board if I knew this was a limitation.
karlshea
Hmmm this actually seems to be an issue with my Windows install... I tried a clean Win11 and Windows can wake itself up even if "BIOS" is selected.
Alan J T
Im guessing you talking about wake from windows sleep or hibernation function and not wake from shut down. And ya windows not like to be swapped from one system to another as different hardware and driver get conflicted. All ways best to do a clean install on a new build.
I don't bother with Sleep as it only take 10 to 15 seconds to boot from a shutdown via windows kind of makes sleep a pointless feature in a lot of cases
karlshea
I was able to fix my original Windows install by toggling hibernation using powercfg and rebooting in between, so now "BIOS" mode is responding to Windows wake timers.
That's fine if you only want to turn the computer on when you're physically next to the computer. If you want it to wake up by itself in the middle of the night for backups, or want to wake it up remotely using wake-on-lan so you can get a file off of it when you're not there, it's a lot less "pointless".
Alan J T
Is why I use google drive and I do Back ups at 11pm everyday. Intel is a much better system for that kind of thing as wake event can work even when PC is shut down via Windows. I was quite surprised at just how flakey the wake events on AMD desktop pc is as never had the same problems with AMD Laptops or intel Systems, But you can set AMD to wake at a set time and do back up provide you setup the system correctly, but as I am now retired I no longer need to do any of that kind of stuff so have not bothered to find a solution for it as I normal have the PC on from 1pm to 2:30 am daily yep I a nighttime person Daylight and working during the day is for saps Night time is the only way to go
kjs_drea15cd02e8
I wanted to help provide some assistance on this dead thread
I had this issue with an Intel board and my Wireless mouse transceiver USB node was causing the issue. I now have the B550 board you can use BIOS to set the system to wake from either keyboard or mouse. I have mouse disabled and keyboard enabled. If the system is sleeping or powered off I can press any key on my keyboard and the system boots/restores state.
So this option is absolutely available on the B550 board.
Another point is that WOL is supported using the directions already listed in this thread - https://forum-en.msi.com/faq/articl...t,is succesful try to wake from Shutdown (S5).
These are confirmed as working. I have two different systems running B550 boards and both have WOL working and a keystroke will power/restore the system. It is odd since these options existed when this thread was created. Apparently the users did not... try hard enough? Zero issues with WOL or wake on B550
Alan J T
Another point is that WOL is supported using the directions already listed in this thread - https://forum-en.msi.com/faq/article/wake-on-lan-wol#:~:text=Run the monitor on the system you want,is succesful try to wake from Shutdown (S5).
I have tried on two Different Boards a B550 and X570 Wake from Keyboard or mouse if Wireless USB do not work for me as well as no luck with wake Via PCIE device.
Believe me I have tried ever combination.
