Wake on lan - MAG Z590 Codex X5
cedri15b202de
Since 2 weeks I have my new Desktop PC to work in my office.
I want to setup Wake on lan, to power up the pc when I'm not home and want to acces my pc remotely.
(I have a raspberry PI in my network at home to send the magic packets)
I've read a lot about enabling Wake on lan, but I cant find the enable options in my Bios. (Erp ready is disabled)
I did a firmware update in the bios (EB930IMSvB20), without any changens. the only option I see:
-Wake up from RTC alarm
I Tried to wake by lan, without any luck. I hope WOL is enabled by default and there's a problem in my complex network.
When my pc is turned off, the Lan Led is still active.
Thanks,
My setup:
MAG Codex X5
msi z590 pro wifi (mainboard)
intel 11900KF
RTX3090
32gb ram
FlyingMog
PRIVATE FIRST CLASS
Hi, you may try to turn off "Turn on fast startup" feature in Windows 10 before shutdown the pc and then check it again. Attachment is for reference or refer to following link to know how to set Wake On Lan feature.
cedri15b202de
Thanks for your reply. It took some time to try it out... But switching off the "turn on gast startup" solved my problem.
Thanks you!
