firdausbangun6156d02dc
- Feb 19, 2022
I encountered this problem, warning !!! please insert usb key press any key check.. please help to restore to initial settings. moteherboard doesn't want to be reset
with what hardware and what are you trying to do and where are you seeing the warning?I encountered this problem, warning !!! please insert usb key press any key check.. please help to restore to initial settings. moteherboard doesn't want to be reset
the warning appears on the monitor the first time it is turned on and can't enter the bioswith what hardware and what are you trying to do and where are you seeing the warning?
did you make a Security USB Key as to me that is sounding like a BIOS U-Key Protection is active and that cant be removed unless its sent to MSI or a Shop that can Overwrite the BIOS chip as its looking for a Security Key.the warning appears on the monitor the first time it is turned on and can't enter the bios
