!!! Warning: Z490 boards - problem with recent BIOS updates !!!
Pro
There is a common problem with the latest BIOS updates for Z490 boards: The update seems to finish, the PC reboots, but then it's stuck with the EZ Debug LED "CPU" being on.
The danger has first appeared with the April/May 2021 BIOS update (changelog: "Improved Audio compatibility"), and may continue with newer updates as well, potentially causing the same issue: The board can become unusable / "bricked" because of a failed flash process.
Note that there is no risk of this with BIOS updates for MSI mainboards using other chipsets (like Z390, B460, Z590, B560, Z690, B660, X470, B450, X570, B550, and so on).
This can only happen on MSI Z490 boards. People with other boards can update normally.
The first reports about a Z490 BIOS update causing problems was at the beginning of May 2021: z490 Tomahawk CPU Debug LED Stuck on after latest BIOS update
Then in May 2021, this thread: Warning : V17 bios for Z490 Gaming Edge Wifi release Monday may brick your board., and several more after.
I have found no reports of problems with any of the earlier BIOS updates, only with the ones from mid-2021 and newer. Also, this problem doesn't happen all the time, otherwise this forum would be absolutely flooded with complaints. But it is a real danger, as you will see below when i list some of the affected users.
Normally i'm all for updating the BIOS, and i do it pretty much immediately on my boards whenever a new BIOS is released. And this Z490 issue is the first such problem i ever saw. But the main problem is: Unlike some newer-generation boards, most of the Z490 boards have no way of recovering from it. For most people, the only way to solve this would be to RMA the board, or try their luck with an external BIOS programming device. The only Z490 boards where it's no problem are the two sister boards MEG Z490 UNIFY and ACE, and the MEG Z490 GODLIKE, because those three have a USB Flashback function (Flash BIOS Button). There you can flash back to an older version and the board works again, or you can even flash the newest version until it works (once the BIOS is successfully flashed, even the three newest versions will work fine).
The newer Z590, Z690 and Z790 boards now almost all have a Flash BIOS Button (and corresponding USB port) on the rear I/O panel through which users can "force-flash" the BIOS in case of problems. So i guess MSI rather add that function everywhere now, instead of dealing with RMAs of bricked boards when something goes wrong. Once you have this "USB Flashback" feature on a board, a problem like this becomes harmless, because you can just re-flash the latest BIOS and make it work again.
I have researched about all the users i could find that have been affected by this, so everyone can see the full scope of the problem. I don't think i exaggerate when i claim that this is a huge problem for MSI and their reputation, and to my knowledge, they have not reacted until this day. They released the September BIOS update for Windows 11 compatibility, and while such an update went well on my Z590 board at the time, as expected (plus it has the safety net of the Flash USB Button), there are still reports of the similar Z490 update potentially causing this problem there. Each day, there are many people updating their BIOS on MSI mainboards without any issues, and only on Z490 boards we see this kind of problem.
As a longtime MSI user, this kind of problem with the Z490 boards is unacceptable, even if i don't have a Z490 board myself.
Therefore, i decided to try to bring further attention to it, so hopefully MSI can do something about it as soon as possible.
Update October 7, 2021: MSI are now seemingly aware of this issue, as was confirmed on a German forum by an official MSI account. I will update this post/thread if there is any progress.
Update October 29, 2021: A user received a link from MSI with a tool for manual flashing from the command line. However, this is just an interim solution if you absolutely want to update to the newest Z490 BIOS and reduce the risk of failure. We are still waiting for them to upload new BIOS updates where this potential problem is 100% fixed.
Update March 6, 2022: Still no solution from MSI.
Update August 17, 2023: Still nothing from MSI, although there are considerably less cases now than there have been two years ago, we barely get any new victims. So maybe the newest BIOS versions are way less problematic again. As for updating an MSI Z490 board, i now recommend using the Forum Flash Tool as linked here. There has been no corrupt Z490 BIOS reported with it yet.
If the problem already happened, the best do-it-yourself solution by far is this kind of method with an external flash programmer (bit more info here), it has a 100% success rate from what i have read so far. Meaning, more or less everyone that seriously tried that method could eventually flash their BIOS with it and get the board back to a working state. So for everyone wanting to avoid a possibly lengthy RMA process, this is a viable option. The programming device is quite cheap, but it involves a bit of research and spirit of adventure. Luckily, there are good guides about it on Youtube for example.
One final word: It is important not to be put off from doing BIOS updates altogether by this. BIOS updates fix bugs, add new features, and they even improve performance. It is extremely rare that a whole line of mainboard models has such a potential problem. So, nobody should conclude never to do any BIOS updates again, that would be the wrong thing to learn from this. Instead, once this problem is fixed for the Z490 boards, the BIOS updates can once again be an important way to make the system work better, faster, and with less bugs. On other boards with a Flash BIOS Button as a safety net, there is literally no reason to shy away from any BIOS updates. Even here with the Z490 boards, whenever users with the the boards Z490 ACE, UNIFY or GODLIKE were affected, they could easily recover from it using the Flash BIOS Button. This problem could only become so big because all the other Z490 board models from MSI didn't have the Flash BIOS Button yet.
Statistics:
Affected total users (from this list and from further replies to this thread): 183
Users that could fix it themselves using the Flash BIOS Button (
Z490 ACE/UNIFY/GODLIKE): 9
Users that could fix it themselves using an external programming device: 12
Users who did an RMA with the vendor or MSI for a fix/replacement: 56
RMA declined because of existing unrelated damage on the board: 4
Users that bought a new board themselves: 9
No further information / no RMA yet: 93
Users that updated via MSI Center / Dragon Center Live Update: 85
Users that updated via M-FLASH in the BIOS: 66
Update method unknown:
32
List of affected users i have found on the forum, as of first posting this thread:
(Roughly in chronological order)
User: @datz.bunz
Date of failed flashing: May 2021
Affected board model: Z490 Tomahawk
CPU: ?
Flashing method used: M-FLASH
Attempted update to BIOS version: 7C80v18
Result: Stuck at EZ Debug LED "CPU" after update. Bought a replacement board (ASUS)
User: @mace014ea02cd
CPU: 10700K
Result: Stuck at EZ Debug LED "CPU" after update. Got a replacement board
User: @dr_overflo153302df
CPU: 10700K
User: @sixpackvbal129b02ae
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI, got his repaired board back
User: @mark.hadda156c02dd
Affected board model: Z490 Tomahawk?
CPU: 10850k
User: @mickh5494
Affected board model: Z490 Gaming Edge
CPU: ?
Attempted update to BIOS version: v17
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI?
User: @kenneth.cotma151802d1
Affected board model: Z490I Unify
CPU: 10700K
Flashing method used: MSI/Dragon Center Live Update
Attempted update to BIOS version: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through vendor, sent to MSI for repair
User: @anglnotre15dd02f0
Affected board model: Z490 Gaming Plus
CPU: 10600K
Result: Stuck at EZ Debug LED "CPU" after update. RMA, got his repaired board back with older BIOS vA6 on
User: @lesurvenan152302d4
Affected board model: Z490 Gaming Edge Wifi
CPU: 10600K
User: @sa3aa14e902d9
CPU: 10700K
Result: Stuck at EZ Debug LED "CPU" after update. Goes "back to ASUS"
User: @jallu_col129b02ae
Date of failed flashing: June 2021
Affected board model: Z490 Gaming Carbon Wifi
CPU: 10900K
Attempted update to BIOS version: v18
Result: Stuck at EZ Debug LED "CPU" after update. RMA denied due to small scratch on the board. Bought a replacement board from different brand
User: @Own3d
Affected board model: Z490 Gaming Edge Wifi ?
CPU: ?
User: @luis.stuardo2151c02d3
CPU: ?
Flashing method used: ?
Result: Stuck at EZ Debug LED "CPU" after update. It will be "his last board from MSI"
User: @tehjacku151402ce
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA denied by MSI (didn't go into detail), got a replacement through insurance
User: @mark.robinson198127b02ab
CPU: ?
User: @dj3for10
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. "Contemplates life in front of dead PC"
User: @jwilby8160102f6
Date of failed flashing: July 2021
CPU: 10700K
Attempted update to BIOS version: v19
User: @ferran.duarr157e02dd
CPU: 11700
User: @Rubik
Affected board model: Z490I Unify ?
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. Successfully repaired it by using a BIOS programmer,
https://forum-en.msi.com/index.php?...after-successful-upgrade.364845/#post-2070108
User: @janschulteortbec154a02d3
CPU: ?
Attempted update to BIOS version: v19?
User: @hardcore_gamer29
CPU: 10900K
Result: Stuck at EZ Debug LED "CPU" after update. RMA through service center, got his repaired board back
User: @yamei031154f02d7
CPU: 10900K
User: @saokirito93156102df
Affected board model: Z490 GAMING EDGE WIFI
CPU: 10600KF
CPU: 10700K
User: @gmbeas160158102e0
CPU: 10700K
User: @mohdrodz15bf02ed
Affected board model: Z490 ?
CPU: ?
User: @mikemauge154a02d7
CPU: 10900
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI, got his repaired board back with BIOS v17 on
User: @xsketchyfruit12fc02b9
Date of failed flashing: August 2021
Affected board model: Z490 Gaming Pro Plus
CPU: 10400
User: @yxh93021154502dc
CPU: ?
User: @John Eisberg
Affected board model: Z490 UNIFY
CPU: 10900K
Attempted update to BIOS version: vA9
Result: Stuck at EZ Debug LED "CPU" after update. Used "Flash BIOS Button" method to force-flash to BIOS vA8, board works again
User: @aaronpeigh
CPU: 10850K
User: @dan.pahal125b02a7
CPU: 10700K
Attempted update to BIOS version: v18?
User: @amichele154f02db
CPU: ?
Attempted update to BIOS version: vA8
User: @j0sefuz115d402ee
CPU: ?
User: @mikkl1620
CPU: 10600K
Result: Stuck at EZ Debug LED "CPU" after update. RMA denied due to slightly bent pins in the CPU socket. Bought a replacement board "Z590 Tomahawk"
User: @yohan.vandevell154002e1
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. Opened a ticket with MSI
User: @jonathan84012e802b5
CPU: ?
User: @takocankol
CPU: ?
User: @christoph.urba128d02aa
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. Wants to attempt manual BIOS flash with CH341A EEPROM programmer,
https://forum-en.msi.com/index.php?...-plus-bios-chip-location.366165/#post-2075572
User: @seeknay7415ae02f0
Date of failed flashing: September 2021
Affected board model: Z490 Gaming Carbon WIFI
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI. "Very unlikely he will buy another MSI board after this"
User: @mastersap157d02db
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI?, got a new board of the same model
User: @stro152c02d9
CPU: 10500
Everyone with the same problem on Z490 that doesn't find themselves on the list, feel free to reply here using the same format, here is a template:
CPU:
Whenever i have seen your reply and included it in the statistics, i will give a "thumbs up" for it to thank you for your participation.
Also, feel free to refer to this thread in your communication with the vendor or with MSI. Hopefully MSI will finally start to recognize this problem and do something about it.
Someone asked me if they can thank me for my work by sending me something via Paypal: Yes, that's possible, just write me a message and i'll tell you my Paypal 😉
Date of failed flashing: 27.10.2021
Affected board model: MAG Z490 Tomahawk
CPU: i7-10700K
Flashing method used: MSI Dragon Center
Attempted update to BIOS version: 7C80v1A
I noticed you updated your BIOS on the MSI Z490 Gaming Edge Wifi...
Did you touch base with MSI customer service prior to doing so to ensure if it is safe to update to this bios?
I inquired about the safetly of bios v.19 when I noticed it was pulled from the list of bios updates and was instructed, " please do not flash the bios by M-Flash or LiveUpdate, if you want to flash the bios in the future, we can provide you a tool to update the bios".
Instead I was given a google drive link to a copy of AFUWININTEL and told to use this for future bios updates; I was also provided with instructions detailing how to use AFUWIN.
This appears to be a work around for the moment.
I did ask if they plan to utilized M-Flash or Control Center in the future but have not heard back yet.
no shot I'm going to reach out to MSI customer service every time I want to update my BIOS with THEIR publicly posted, non-beta version updates, just to "double check this one won't brick my whole motherboard this time".
I've RMA'd the board since I've only had it for 6 or so months, but I'll be upgrading to a non-MSI board after I've had this one for a year or so
With the Z490 ACE, you have no problem. Just use the Flash BIOS Button to flash an older BIOS version, or flash the current BIOS version until it works again.
My old Asus board from 2012 had the exact same system USB and flash button for bios recovery. I wrongly thought all MB from there had this feature, and that's note the case with the Gaming Edge Wifi I own. Lesson learned, even if all went fine for me so far. I really can't get stuck with my computer at this period of my life...
index.php
Format the USB stick as FAT32 non-bootable with the help of https://rufus.ie/en/ (i would use this tool, it has more of chance of working than letting Windows format it).
You don't have to take out any hardware like your CPU for this, it's just a demonstration in the video.
Thank you, it worked for me without rufus (i formatted my usb with windows), thank god there is people like you helping. Anyway, I always do a Mflash, this time i tried their .exe update. I will never try it again. Have a nice day
Date of failed flashing: 28/10/2021
Affected board model: Z490-A Pro
CPU: i5 10600k
Flashing method used: MSI LIVE UPDATE
Attempted update to BIOS version: 7C75v2C
No CPU OC , 2 sticks of RAM 3200Mhz
Happened to me once before and was solved after shortcutting CMOS. Not anymore it seems.
CPU: i5 10600k
Attempted update to BIOS version: 7C71v1C
The BIOS that we have for the latest for the Z490 A Pro is 7C75v2C Is the number you have quoted a typo?
New bios listed for Z490 Unify.
For the Z490 ACE, UNIFY and GODLIKE, this whole problem might as well not exist. They have a Flash BIOS Button and can always recover from a failed flashing process. So whatever BIOS they release, even if the update fails on the first try, on those boards you can just force-flash it again until it works.
As for the "new" update, this is pretty much the same update they temporarily pulled before. According to two users who tried to flash this "new" update on their lesser Z490 models, they got the problem again, so it's not fixed by that update alone.
https://forum-en.msi.com/index.php?...ecent-bios-updates.367575/page-8#post-2086888
https://forum-en.msi.com/index.php?...ecent-bios-updates.367575/page-9#post-2087112
The most recent sign of MSI working on this issue was this post with the AFUWINx64 method, but surely MSI can't expect lots of people to use command line tools again like 15, 20 years ago.
I'm hoping for genuinely new updates soon that will fix this potential problem once and for all.
But has anyone tried the AFUWINx64 method?
Some expert on the subject can put a tutorial and if this method does not give an error, we use it while they correct the error and we avoid dead motherboard.
Adding myself to the list. Had to RMA. They returned the same physical motherboard to me so they must have a way to unbrick it.
Date of failed flashing: September 7, 2021
Affected board model: MPG Z490M Gaming Edge Wifi
CPU: 10700k
Flashing method used: m-flash
Attempted update to BIOS version: from 2.7 to 2.9
Date of failed flashing: 08-Oct-2021
Affected board model: MAG Z490 TOMAHAWK
CPU: i7-10700
Flashing method used: Using M-Flash from BIOS (BIOS file was stored on NVMe OS Drive)
Attempted update to BIOS version: Version 7C80v19 to 7C80v1A.
Memory: Corsair Vengeance LPX 32GB (4x8GB) 3200MHz CL16
Overclocked: No
So I've sent the board for RMA and is back and working after 2 weeks.
A very interesting finding is that my Intel NIC now has this MAC Address 88-88-88-88-87-88
I've tried a bootable linux installer and it shows the same MAC so is not spoofed by the OS.
Date of failed flashing: 28/Oct/2021
CPU: nI5 10600k
Flashing method used: Msi center
Attempted update to BIOS version: not sure the latest from 7C75vA9
CPU: nI5 10600k
That BIOS does not even show on the support page we have, the latest is 7C75vAA ,and before that 7C75vA8 so it may be one that was taken down .
Дата неудачной перепрошивки: 30 октября 2021 г.
Затронутая модель платы: Z490 Gaming edge wifi
Процессор: I7 10700f
Используемый метод прошивки: Msi center
Попытка обновления до версии BIOS: от версии 7C79v18 до 7C79v1A.
Результат: зависание на индикаторе EZ Debug "CPU" после обновления
Date of failed flashing: OCT/30/2021
Affected board model: Z490 Gaming Edge Wi-Fi
CPU: i9-10850k
Flashing method used: Dragon Center ?
Attempted update to BIOS version: from 1.7 to 1.9
Result: Black screen -Fans on, lights on, mouse on
OK so I am unbricked now using a CH341A USB programmer. It was a bit difficult having never used one before but 2 hours of messing around learning how it works and $15 and I am back in business.
Z490 Tomahawk. I reverted to 7C80v18. I havent tried updating to 7C80v1A again.
did you unsolder or use the tweezers? I tried to use that programmer and now my board won't turn on
