!!! Warning: Z490 boards - problem with recent BIOS updates !!!
Pro
There is a common problem with the latest BIOS updates for Z490 boards: The update seems to finish, the PC reboots, but then it's stuck with the EZ Debug LED "CPU" being on.
The danger has first appeared with the April/May 2021 BIOS update (changelog: "Improved Audio compatibility"), and may continue with newer updates as well, potentially causing the same issue: The board can become unusable / "bricked" because of a failed flash process.
Note that there is no risk of this with BIOS updates for MSI mainboards using other chipsets (like Z390, B460, Z590, B560, Z690, B660, X470, B450, X570, B550, and so on).
This can only happen on MSI Z490 boards. People with other boards can update normally.
The first reports about a Z490 BIOS update causing problems was at the beginning of May 2021: z490 Tomahawk CPU Debug LED Stuck on after latest BIOS update
Then in May 2021, this thread: Warning : V17 bios for Z490 Gaming Edge Wifi release Monday may brick your board., and several more after.
I have found no reports of problems with any of the earlier BIOS updates, only with the ones from mid-2021 and newer. Also, this problem doesn't happen all the time, otherwise this forum would be absolutely flooded with complaints. But it is a real danger, as you will see below when i list some of the affected users.
Normally i'm all for updating the BIOS, and i do it pretty much immediately on my boards whenever a new BIOS is released. And this Z490 issue is the first such problem i ever saw. But the main problem is: Unlike some newer-generation boards, most of the Z490 boards have no way of recovering from it. For most people, the only way to solve this would be to RMA the board, or try their luck with an external BIOS programming device. The only Z490 boards where it's no problem are the two sister boards MEG Z490 UNIFY and ACE, and the MEG Z490 GODLIKE, because those three have a USB Flashback function (Flash BIOS Button). There you can flash back to an older version and the board works again, or you can even flash the newest version until it works (once the BIOS is successfully flashed, even the three newest versions will work fine).
The newer Z590, Z690 and Z790 boards now almost all have a Flash BIOS Button (and corresponding USB port) on the rear I/O panel through which users can "force-flash" the BIOS in case of problems. So i guess MSI rather add that function everywhere now, instead of dealing with RMAs of bricked boards when something goes wrong. Once you have this "USB Flashback" feature on a board, a problem like this becomes harmless, because you can just re-flash the latest BIOS and make it work again.
I have researched about all the users i could find that have been affected by this, so everyone can see the full scope of the problem. I don't think i exaggerate when i claim that this is a huge problem for MSI and their reputation, and to my knowledge, they have not reacted until this day. They released the September BIOS update for Windows 11 compatibility, and while such an update went well on my Z590 board at the time, as expected (plus it has the safety net of the Flash USB Button), there are still reports of the similar Z490 update potentially causing this problem there. Each day, there are many people updating their BIOS on MSI mainboards without any issues, and only on Z490 boards we see this kind of problem.
As a longtime MSI user, this kind of problem with the Z490 boards is unacceptable, even if i don't have a Z490 board myself.
Therefore, i decided to try to bring further attention to it, so hopefully MSI can do something about it as soon as possible.
Update October 7, 2021: MSI are now seemingly aware of this issue, as was confirmed on a German forum by an official MSI account. I will update this post/thread if there is any progress.
Update October 29, 2021: A user received a link from MSI with a tool for manual flashing from the command line. However, this is just an interim solution if you absolutely want to update to the newest Z490 BIOS and reduce the risk of failure. We are still waiting for them to upload new BIOS updates where this potential problem is 100% fixed.
Update March 6, 2022: Still no solution from MSI.
Update August 17, 2023: Still nothing from MSI, although there are considerably less cases now than there have been two years ago, we barely get any new victims. So maybe the newest BIOS versions are way less problematic again. As for updating an MSI Z490 board, i now recommend using the Forum Flash Tool as linked here. There has been no corrupt Z490 BIOS reported with it yet.
If the problem already happened, the best do-it-yourself solution by far is this kind of method with an external flash programmer (bit more info here), it has a 100% success rate from what i have read so far. Meaning, more or less everyone that seriously tried that method could eventually flash their BIOS with it and get the board back to a working state. So for everyone wanting to avoid a possibly lengthy RMA process, this is a viable option. The programming device is quite cheap, but it involves a bit of research and spirit of adventure. Luckily, there are good guides about it on Youtube for example.
One final word: It is important not to be put off from doing BIOS updates altogether by this. BIOS updates fix bugs, add new features, and they even improve performance. It is extremely rare that a whole line of mainboard models has such a potential problem. So, nobody should conclude never to do any BIOS updates again, that would be the wrong thing to learn from this. Instead, once this problem is fixed for the Z490 boards, the BIOS updates can once again be an important way to make the system work better, faster, and with less bugs. On other boards with a Flash BIOS Button as a safety net, there is literally no reason to shy away from any BIOS updates. Even here with the Z490 boards, whenever users with the the boards Z490 ACE, UNIFY or GODLIKE were affected, they could easily recover from it using the Flash BIOS Button. This problem could only become so big because all the other Z490 board models from MSI didn't have the Flash BIOS Button yet.
Statistics:
Affected total users (from this list and from further replies to this thread): 183
Users that could fix it themselves using the Flash BIOS Button (
Z490 ACE/UNIFY/GODLIKE): 9
Users that could fix it themselves using an external programming device: 12
Users who did an RMA with the vendor or MSI for a fix/replacement: 56
RMA declined because of existing unrelated damage on the board: 4
Users that bought a new board themselves: 9
No further information / no RMA yet: 93
Users that updated via MSI Center / Dragon Center Live Update: 85
Users that updated via M-FLASH in the BIOS: 66
Update method unknown:
32
List of affected users i have found on the forum, as of first posting this thread:
(Roughly in chronological order)
User: @datz.bunz
Date of failed flashing: May 2021
Affected board model: Z490 Tomahawk
CPU: ?
Flashing method used: M-FLASH
Attempted update to BIOS version: 7C80v18
Result: Stuck at EZ Debug LED "CPU" after update. Bought a replacement board (ASUS)
User: @mace014ea02cd
CPU: 10700K
Result: Stuck at EZ Debug LED "CPU" after update. Got a replacement board
User: @dr_overflo153302df
CPU: 10700K
User: @sixpackvbal129b02ae
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI, got his repaired board back
User: @mark.hadda156c02dd
Affected board model: Z490 Tomahawk?
CPU: 10850k
User: @mickh5494
Affected board model: Z490 Gaming Edge
CPU: ?
Attempted update to BIOS version: v17
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI?
User: @kenneth.cotma151802d1
Affected board model: Z490I Unify
CPU: 10700K
Flashing method used: MSI/Dragon Center Live Update
Attempted update to BIOS version: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through vendor, sent to MSI for repair
User: @anglnotre15dd02f0
Affected board model: Z490 Gaming Plus
CPU: 10600K
Result: Stuck at EZ Debug LED "CPU" after update. RMA, got his repaired board back with older BIOS vA6 on
User: @lesurvenan152302d4
Affected board model: Z490 Gaming Edge Wifi
CPU: 10600K
User: @sa3aa14e902d9
CPU: 10700K
Result: Stuck at EZ Debug LED "CPU" after update. Goes "back to ASUS"
User: @jallu_col129b02ae
Date of failed flashing: June 2021
Affected board model: Z490 Gaming Carbon Wifi
CPU: 10900K
Attempted update to BIOS version: v18
Result: Stuck at EZ Debug LED "CPU" after update. RMA denied due to small scratch on the board. Bought a replacement board from different brand
User: @Own3d
Affected board model: Z490 Gaming Edge Wifi ?
CPU: ?
User: @luis.stuardo2151c02d3
CPU: ?
Flashing method used: ?
Result: Stuck at EZ Debug LED "CPU" after update. It will be "his last board from MSI"
User: @tehjacku151402ce
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA denied by MSI (didn't go into detail), got a replacement through insurance
User: @mark.robinson198127b02ab
CPU: ?
User: @dj3for10
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. "Contemplates life in front of dead PC"
User: @jwilby8160102f6
Date of failed flashing: July 2021
CPU: 10700K
Attempted update to BIOS version: v19
User: @ferran.duarr157e02dd
CPU: 11700
User: @Rubik
Affected board model: Z490I Unify ?
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. Successfully repaired it by using a BIOS programmer,
User: @janschulteortbec154a02d3
CPU: ?
Attempted update to BIOS version: v19?
User: @hardcore_gamer29
CPU: 10900K
Result: Stuck at EZ Debug LED "CPU" after update. RMA through service center, got his repaired board back
User: @yamei031154f02d7
CPU: 10900K
User: @saokirito93156102df
Affected board model: Z490 GAMING EDGE WIFI
CPU: 10600KF
CPU: 10700K
User: @gmbeas160158102e0
CPU: 10700K
User: @mohdrodz15bf02ed
Affected board model: Z490 ?
CPU: ?
User: @mikemauge154a02d7
CPU: 10900
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI, got his repaired board back with BIOS v17 on
User: @xsketchyfruit12fc02b9
Date of failed flashing: August 2021
Affected board model: Z490 Gaming Pro Plus
CPU: 10400
User: @yxh93021154502dc
CPU: ?
User: @John Eisberg
Affected board model: Z490 UNIFY
CPU: 10900K
Attempted update to BIOS version: vA9
Result: Stuck at EZ Debug LED "CPU" after update. Used "Flash BIOS Button" method to force-flash to BIOS vA8, board works again
User: @aaronpeigh
CPU: 10850K
User: @dan.pahal125b02a7
CPU: 10700K
Attempted update to BIOS version: v18?
User: @amichele154f02db
CPU: ?
Attempted update to BIOS version: vA8
User: @j0sefuz115d402ee
CPU: ?
User: @mikkl1620
CPU: 10600K
Result: Stuck at EZ Debug LED "CPU" after update. RMA denied due to slightly bent pins in the CPU socket. Bought a replacement board "Z590 Tomahawk"
User: @yohan.vandevell154002e1
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. Opened a ticket with MSI
User: @jonathan84012e802b5
CPU: ?
User: @takocankol
CPU: ?
User: @christoph.urba128d02aa
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. Wants to attempt manual BIOS flash with CH341A EEPROM programmer,
User: @seeknay7415ae02f0
Date of failed flashing: September 2021
Affected board model: Z490 Gaming Carbon WIFI
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI. "Very unlikely he will buy another MSI board after this"
User: @mastersap157d02db
CPU: ?
Result: Stuck at EZ Debug LED "CPU" after update. RMA through MSI?, got a new board of the same model
User: @stro152c02d9
CPU: 10500
Everyone with the same problem on Z490 that doesn't find themselves on the list, feel free to reply here using the same format, here is a template:
CPU:
Whenever i have seen your reply and included it in the statistics, i will give a "thumbs up" for it to thank you for your participation.
Also, feel free to refer to this thread in your communication with the vendor or with MSI. Hopefully MSI will finally start to recognize this problem and do something about it.
Someone asked me if they can thank me for my work by sending me something via Paypal: Yes, that's possible, just write me a message and i'll tell you my Paypal 😉
About CH341A programmer
Do I use the BIOS from MSI website to write to the BIOS chip?
Do I need to change the filename or file format?
To anyone trying to re-flash their BIOS chip with a CH341A programmer, double check your chip voltage tolerance and be aware the IO ports of widely available programmer have 5V I/O ports
For a one time flash, probably the BIOS chip can survive but there is no guarantee ... otherwise you might want to modify your programmer
Date of failed flashing: 14.9.2021
Affected board model: MSI Z490 TOMAHAWK
CPU: i9-10850K
Flashing method used: M-Flash
Attempted update to BIOS version: 7C80v19
The board was replaced with new one by retailer.
I came here to see if I should even think about flashing latest v1A BIOS and apparently that wouldn't be a good idea.
Date of failed flashing: OCT/15/2021
Affected board model: MPG Z490 Gaming Plus
CPU: i9-10900KF
Attempted update to BIOS version: from A6 to A9
Result: BRICKED! No power at all, machine wont even power up to lights on nobody home. PSU tested Ok!
Date of failed flashing: 9.10.2021
Affected board model: MSI Z490i Unify
CPU: i5-10600K
Attempted update to BIOS version: 7C77v1A
Before that, I updated the BIOS several times, everything was successful. The seller (Amazon.de) has already sent me a new Z490 instead and it will arrive in about a week or two.
But I had to buy a Z590i Unify board, it had the first release BIOS. I have updated to the latest version 7D05v13. Everything went well.
I also ordered CH341A for myself, just in case.
Z490 Gaming Edge board bricked by recent BIOS update. MSI replaced board with 1.9 installed. Now trying to recover RAID M2 configuration. Anyone else finding that the M2 Remapping Enable setting is missing from the new BIOS?
I had no idea about this topic and cluelessly updated my Z490 Unify with latest september bios and had no problems. I check m/b driver/bios support page everyday for updates and noticed that they removed latest problematic bioses from the list. I believe they will release stable and bug free bios in near future. Thank you for being informative and all your helps. @citay
With the Z490 Unify you have nothing to worry about, because it has the Flash BIOS Button feature. With it, you can always force-flash the BIOS in case of problems. So for example you can force-flash a problematic BIOS a couple times until it works (because the flashing process doesn't always seem to fail), or you can force-flash to an older BIOS version. The trouble for a lot of other people is that their Z490 board model doesn't have this USB flashback feature, so they usually have to send the board out for repair/replacement. This BIOS bricking problem conclusively shows how important this feature can be on a board.
I managed to install all bios updates since i own my z490a pro without any problems. Latest bios (with the win11 and other things) also installed fine but today i saw it got removed from the support page.
Just want to follow up with folks that sent in an RMA for their Z490 boards. Did you receive yours back repaired? Or you got a brand new one? How long (many days) did it take for the entire process?
Date of failed flashing: 26 August 2021
Affected board model: Z490 gaming edge wifi
CPU: I9-10900KF
Flashing method used: Dragon center
Attempted update to BIOS version: 1.7 to 1.8
Mine was a brand new one, I'm 99% sure (Z490 gaming edge wifi). Windows detected a hardware change and wanted me to reactivate it. Also it had all the brand new cpu cover + plastic film.
I still have all the RMA emails and tracking so I can provide a pretty specific timeline:
-Thursday 26th of August 8pm, I dropped it off at Canada Post (I went with a 2 day delivery)
-Saturday 28th, they received it
-Monday 30th 5pm, they processed it
-1 hour later a "replacement" was shipped
-Wednesday Sept 1st, I received it in the morning
Originally they'd told me on the phone it could take anywhere between 3 to 15 business days for the processing alone.
But as you can see, it was much quicker for me, literally an hour (as far as the tracking can tell). Hopefully it's just as fast for you.
was wondering why lately dragon center says it can't reach the server when I have it check for bios updates.
hadn't bothrred updating since none of the changes looked like they were something I needed...waiting on win 11 for MS to work out their kinks.
guess that's a good thing. though I guess I'm fortunate I have a unify
I am curious though, with anyone that has a flashback button, if they tried reflashing the bad bios to see if it would take?
CPU: ?
There is a common problem with the two or three latest BIOS updates for Z490 boards: The update seems to finish, the PC reboots, but then it's stuck with the EZ Debug LED "CPU" being on.
There seems to be a danger from the April/May BIOS update (changelog: "Improved Audio compatibility"), from the July update (changelog: "Support M2 PCIE lanes switch function."), and first reports about the September update (changelog: "Windows 11 Supported, Improved compatibility for Intel Thunderbolt devices.") potentially causing the same issue: The board becomes unusable.
The first reports about a Z490 BIOS update causing problems was at the beginning of May: z490 Tomahawk CPU Debug LED Stuck on after latest BIOS update
Then in May, this thread: Warning : V17 bios for Z490 Gaming Edge Wifi release Monday may brick your board., and several more after.
Note that there is no risk of this happening with BIOS updates on MSI mainboards using other chipsets (Z590, X570, B550, ...), only on MSI Z490 boards with the last three BIOS updates.
I have found no reports of problems with any of the earlier BIOS updates. So i urge everyone to not update to any of those latest three versions until this possible problem is solved. I say possible, because it probably doesn't happen all the time, otherwise this forum would be absolutely flooded with complaints. But it is a real danger, as you will see below when i list some of the affected users.
Normally i'm all for updating the BIOS, and i do it pretty much immediately on my boards whenever a new BIOS is released. And this Z490 issue is the first such problem i ever saw. But most of the Z490 boards have no way of recovering from it. For most people, the only way to solve this would be to RMA the board. The only Z490 boards where it's no problem are the two sister boards MEG Z490 UNIFY and ACE, and the MEG Z490 GODLIKE, because those three have a BIOS Flashback function (Flash USB Button). There you can flash back to an older version and the board works again.
The more recent Z590 ATX boards now all have a Flash BIOS Button (and corresponding USB port) on the back, through which you can "force-flash" the BIOS in case of problems. So i guess MSI rather add that function everywhere now, instead of dealing with RMAs of bricked boards when something goes wrong.
I have researched about all the users i could find that have been affected by this, so everyone can see the full scope of the problem. I don't think i exaggerate when i claim that this is a huge problem for MSI and their reputation, and to my knowledge, they have not reacted until this day. They released the September BIOS update for Windows 11 compatibility, and while such an update went well on my Z590 board as expected (plus it has the safety net of the Flash USB Button), there are still reports of the similar Z490 update potentially causing this problem there. Each day, there are many people updating their BIOS on MSI mainboards without any issues, and only on Z490 we see this kind of problem.
It is important not to be put off from doing BIOS updates altogether by this. BIOS updates fix bugs, add new features, and they even improve performance. It is extremely rare that a whole line of mainboard models has such a potential problem. So, nobody should conclude never to do any BIOS updates again, that would be the wrong message. Instead, once this problem is fixed for the Z490 boards, the BIOS updates can once again be an important way to make the system work better, faster, and with less bugs.
What follows is a list i made of the affected users to date just here on this forum (and i'm sure i missed some posts).
Statistics:
Affected total users (from this list and from further replies to this thread): 76
Users that could fix it themselves: 4 (3x Flash BIOS Button, 1x external programming device)
Users who did an RMA with the vendor or MSI for a fix/replacement: 28
Users where the RMA was declined: 3 (2x because of existing damage to the board, 1x not stated)
Users that bought a new board themselves: 5
No further information / no RMA yet: 36
Users that updated via MSI/Dragon Center Live Update: 22
Users that updated via M-FLASH: 35
Update method unknown: 19
User: @datz.bunz
CPU: ?
CPU: 10700K
CPU: 10700K
CPU: ?
CPU: 10850k
User: @mickh5494
CPU: ?
CPU: 10700K
CPU: 10600K
CPU: 10600K
CPU: 10700K
CPU: 10900K
User: @Own3d
CPU: ?
CPU: ?
CPU: ?
CPU: ?
User: @dj3for10
CPU: ?
CPU: 10700K
CPU: 11700
User: @Rubik
CPU: ?
CPU: ?
CPU: 10900K
CPU: 10900K
CPU: 10600KF
CPU: 10700K
CPU: 10700K
CPU: ?
CPU: 10900
CPU: 10400
CPU: ?
User: @John Eisberg
CPU: 10900K
User: @aaronpeigh
CPU: 10850K
CPU: 10700K
CPU: ?
CPU: ?
User: @mikkl1620
CPU: 10600K
CPU: ?
CPU: ?
User: @takocankol
CPU: ?
CPU: ?
CPU: ?
CPU: ?
User: @stro152c02d9
CPU: 10500
Users from other forums with confirmed cases: stiffmeister53, d-Udo, msiz490b, HeavenRL, hubihh
CPU:
CPU:
Date of failed flashing: OCT/2/2021
Affected board model: Z490 Gaming Edge Wi-Fi
CPU: i9-10850
Attempted update to BIOS version: from 1.7 to 1.9
Result: BRICKED! Black screen - lights on, no one's home (in other words, it's running, but dead anyways)
[/QUOTE]
User: @sosemprelumejo
Date of failed flashing: October 2021
Affected board model: MEG Z490I Unify ?
CPU: i5-10600KF
I think you made a bit of a mess there with the quotes in your post, but i will include you in the statistics, thank you.
Finally! MSI managed to do the obvious thing and take down the faulty BIOS from the Z490I Unify page...
Yes, i think they're withdrawing the latest update for all the Z490 board models now. However, as i wrote in the first post, the first reports about this issue came back in May, with a BIOS that was two versions older. So this can happen with the last three BIOS updates, not just the latest one. Therefore, i'm not sure why they only withdrew the latest one. Well, let's see what solution they come up with.
Could you please confirm the model of the BIOS chip you have? It's here:
Please only post in English here, but yes, that is most likely the BIOS chip. If you can tell me what's written on there, i can double-check.
