water cooler coreliquid D360mm
estou tendo problemas com a inicialização da tela da minha bomba para inicializar o software da bomba, ele fica tentando conectar e não consegue, já desinstalei o programa e instalei novamente, já exclui todos os arquivos residuais do programa depois da desinstalação e instalei o programa novamente e mesmo assim não funcionou,
estou deixando meu computador só com peças da MSI e está me deixando chateado esse problema com meu water cooler, alguém poderia me ajudar? eu estou usando a versão do Windows mais recente.
I am having problems with the startup of the screen of my pump to initialize the pump software; it keeps trying to connect and cannot. I have already uninstalled the program and reinstalled it, deleted all the residual files of the program after uninstallation, and installed the program again, but it still didn't work. I am only using components from MSI in my computer, and this problem with my water cooler is making me upset. Could someone help me? I am using the latest version of Windows.It was just to have translated it on Google Translate; it's not very difficult.
Does it shows USB connection failed or just black screen?
Have you double-checked the USB cable is correctly inserted into your motherboard USB header?
Have you tried to temporarily removed other USB devices and test again?
Btw since this is global forum, it's suggested to post in English.
