Weird Fan Noise
srojasbravo158702e0
Hi everyone! I just bought an MSI Vector 16HX with this specs:
  • Ryzen 9 8940HX
  • RTX 5070 Ti
  • 16 GB RAM
  • 1 TB SSD
After playing for a while today, I noticed that the left fan made a weird noise during shutdown. Since then, the same noise appears every time I shut down or turn on the laptop, and sometimes even during normal use. It seems to happen only at low RPMs. I checked the RPMs in the MSI Center while using the cooler boost mode and found that the fan 1 spins at ~6800 RPM while the Fan 2 at ~7500 RPM. I’m not sure if this RPM difference is normal or related to the noise.
Here's a video where you can hear the strange fan noise when shutting down: https://drive.google.com/file/d/18F0nS17nXWHgB-TMbmkA95vrfsGQOXQM/view?usp=sharing
Has anyone experienced something similar or knows what could be happening?
My laptop's fans are also spinning at different speeds.
I'm not sure if they've always been like that.
But they're not making any strange noises. Maybe you should contact support.
