Weird monitor noises... anyone else experiencing same?
uga.ar150002cf
Hi everyone,
I´ve just bought a new computer and a monitor (MSI PRO MP271P), that has integrated speakers. The computer doesn´t have HDMI so I´ve used a VGA and a sound cable to connect it to the monitor.
Well the problem is: even if the sound is at 0 volume, the monitor makes so weird and annoying noises constantly and specially when moving the mouse. When unplugging the sound cable there is no noise, but of course no sound either 😕.
At first thought it was the cable that was old, but tried with a good one and happened exactly the same. When connecting the cable to the monitor and touching the other end with my finger, the noise is even louder.
I´m just desperate as I don´t know what else I can do. Any idea?
TIA
fauc
Active member
SECOND LIEUTENANT
Please use another computer that with HDMI to check it again.
FlyingMog
PRIVATE FIRST CLASS
If you use early graphic card and connect D-Sub(VGA) on monitor, please do not use sound cable to connect the monitor and try to use external sound speakers or upgrade the graphic card with HDMI feature.
