Weird Noise Left Side
gifford152a02de
After doing the bios upgrade a few days ago on bootup on my Claw A1M the left side makes a vibrating noise on bootup all the time, and randomly on game play, warranty time? Looking for opinions on this.
You can try to do EC reset first, shutdown and unplug the AC > long press the power button for over 25 seconds > plug in the AC and power on
If the noise is still there, would you please share a video about it?
I'm getting this after recent bios upgrade as well, I havnt done a ec reset yet, as it only is the vibration motor tweaking at start up.
Me too i have same problem after upgrade new firmware. When bootup, 4 times vibration noise will be come. I do EC Reset but no hope, anyone any suggestions for thiz problem please?
I already updated BIOS to the latest version E1T41IMS.10D in January, but there is no abnormal sound.
Did you guys update BIOS using the download package from MSI website or update through Center M software?
Make sure to check your BIOS version is E1T41IMS.10D, which is the latest version.
Also, if you can easily replicate the issue, would you please share any video here?
im use the latest bios right now. E1T41IMS.10D. After update gamepad firmware 1.63. The problem Like suddenly your device vibration like haptic feedback when turn on sleep mode or boot. Really annoying you know feel like 100 volume vibration. 4 times T_T
Send it to the service center for further assistance. The firmware is related to controlling the joysticks and buttons, has no reason to affect the fan.
I have the same problem after the last update and it so annoying, how it can be fixed?
Try EC reset first, shutdown the device and unplug the charger > long press the power button for over 25 seconds > plug in the charger and power on the device.
If it is possible, share a video to help everyone understand more clearly about the issue.
I also have this issue since the latest firmware, A strong vibration on startup and sleep as well as happening at random. Hopefully there will be a fix it is annoying.
My Claw A1M is same. A strong vibration on startup and sleep. This doesn't happen if I revert the firmware to 1.61.
I am also experiencing the same issue. Hesitant to downgrade the firmware (not that I can find where to source it) as it fixed many other bugs I had prior. I've raised a ticket and asked MSI if this is a known issue so will update if I find out.
same problem almost week old, at first unboxing there's no noise coming from the left, then after updating all bios the noise came. any suggestion?
