What ram? Mag X870 tomahawk wifi-Ryzen 9 9900x
inf156402e6
Hi All,
I recently purchased an msi mag X870 tomahawk wifi motherboard with Ryzen 9 9900X and 98gb corsair vengeance argb (2x48gb 6000mhz cas32).
After running cpuid etc, I found that the ram listed as cas 32 is actually cas40-40-36 so sending it back.
My Question is please if you can assist, what compatible ram to go for? Doesn't have to be corsair and I think maybe 98gb is overkill so will go for 64gb (2x32gb) but want argb and low cas/Cl at least 30/32 with 6400mhz for room to oc.
Thank you
Same MB and CPU here.
I use Adata/XPG Lancer Blade RGB.
Works great on Expo with 6400 / cl32.
However, I have 32gb (2x16) which is more than enough for my needs.
64gb from Adata/XPG you can find on Google --> AX5U6400C3232G
Thank you..
Not sure what would be best, 6400mhz cl32 or 6000mhz CL30.
If they do it, either 1x64gb or 2x32gb if I can use only 1 rail/slot.
Want white with argb though
