Claw is a handheld gaming device, so battery life can vary a lot depending on the game, performance mode, screen brightness, refresh rate, and background apps.
You can try the following settings to reduce battery drain:
1. Set MSI Center M to a lower performance mode, such as Balanced or Super Battery.
2. Lower the TDP / performance level if available.
3. Reduce screen brightness.
4. Lower the refresh rate from 120Hz to 60Hz.
5. Turn off RGB lighting if enabled.
6. Close unnecessary background apps and game launchers.
7. Disable Bluetooth / Wi-Fi if you do not need them.
8. Use lower in-game graphics settings and limit FPS, for example to 30 or 40 FPS.
9. Make sure BIOS, EC firmware, MSI Center M, Intel graphics driver, and chipset driver are updated from the MSI support page.
Also make sure the device is not running in a hot environment, as higher temperature may increase fan speed and power consumption.
