What software to pilot the installed fans (and maybe aditionnals fans) in my PANO 100R PZ
philippe.hu15d502ec
Hi, i assemble my first PC with ARGB fans. There are 4 installed in my box, but i cannot control the speed for these 4 (maybe i do not use the good software). i add 3 Bequiet fans on the bottom of the box. ICue didn't detect them at all and i struggle to get control on all the set.
if it can help, i have an Asus Motherboard, an AIO Corsair Titan and a GPU EVGA.
Which "box" you talking about, do you mean chassis? or the control board?
Most likely the fan is connected to the mainboard, since you're using ASUS board, you use ASUS software to control fan.
Hi, thanks for your support. i baddly translate my meaning, maybe due to the fact that i'm french. By Box, i mean chassis. I bought a chassis MSI MAG PANO 100R PZ that have 4 fans pre installed. The 4 fans are connected to a hub (visibly the control board that you put in your answer).
I add 3 fans bequiet on the bottom of the chassis. They are directly connected on my ASUS main board and are working properly.
When i use the 'led' button on the MSI chassis, all the 7 fans are right adjusting on color settings.
Where i struggle is first of all with speed adjustments. The MSI Fans don't accept the ASUS FanXpert settings. I think that i missed something or do something wrong, because my Bequiet fans are managed on my ASUS FanXpert app, but not the 4 pre installed.
I see a white fan on the control board. Do i need to connect this to the mainboard ?
Yes, yesterday, i checked all my connections. I know the hub is connected on the CHA FAN1, my 3 BQuiet fans on 2, 3 and 4. I think i cannot do better than that.
Now i have one problem to solve : Associating a fan profile to one or more applications like my games. There require a different profile (more fan power) than my desktop mode.
Ok, Thank you for your time spent on my question. At this point, i've find some kind of compromise with Armory Crate, at minima for the fans profile.
Designing ARGB led will come later.
Thank you
