Sorry I forget my login password so i could not log back in so i opened another one.
I need basically browsing internet maybe some ai stuff i was running my local ai using ollama that is just like copilot but with privacy benifits.
And some games mainly i only play few games cod gtaV Elden Ring just bought cyberpunk witcher froza 5 that is all i play maybe i will play something else in future.
Forget to mention i used to play minecraft so this all should be playable.
The ai models i run are llama3 8b and deepaseekv2 16b but i would like to run a larger model not 72 maybe aya 35b or something.
Also i watch movies online amazon prime and ...also ofline movies
And i also need wifi 6e as i just bought a wifi 6 router.
I have a good 5.1 sound system i also run this on my system.
Also i use Bluetooth headphone wired also.
I read pdf also edit them and basic office stuff.
On ms office which i run on wine.
This all should work.
My old system was 16gb rm and amd r7 cpu and some nvidia gpu was there can't remember the name and i will buy all the stuff new i will just use my monitor. And sell the old one. Thanks.
Also if possible suggest me a system in where i can put snapdragon cpus when it will ve available in future.
Snapdragon CPU's won't make their way to desktops (yet) really. I wouldn't even worry about them at this point......
Truth be told, if you really want that AI side of things, you might want to wait 3 to 6 months for the next Intel release (or maybe AMD, all depends). Their next release will have a lot more AI capabilities built into them, unlike the current 13th or 14th gen CPU's which really don't.
If you're hard up on building something right now, then probably a 14th gen i5 or i7 would work fine and is well within that price range. More or less :
Intel i5 or i7 (14700 = $400USD, 14500 = $240)
MSI B760 Gaming Plus WIFI ($160)
32GB DDR5 (~$110 for 2x16GB, like Corsair Vengeance RGB DDR5 6400 MHz CL36 model # CMH32GX5M2B6400C36)
Deep Cool LT720 cooler (requires a case that can handle a 360mm cooler, ~$140)
NVMe ~2TB (WD Black SN770, Crucial T500, Lexar NM790, all are around $150)
GPU - MSI RTX 4070 Ventus 2x $550, MSI RTX 4070 Ventus 3x $555, MSI RTX 4070 Super Ventus 3x $630, MSI RTX 4070 Ti Super $800, MSI RTX 4070 Super Ventus 2x $620 (pick whichever you'd like)
Power supply - MSI MPG A1000G $195, MSI MAG A1000GL $160, Corsair RM1000x $170, Corsair RM850e $120 (all of these are good and highly rated supplies I might add, I wouldn't stray from these)
Case - MSI MPG Gungnir 111R $90, MSI MAG Forge 321R $70, MSI MAG PANO M100R PZ $110, or just about any other for $100 to $150
That list above, comes out to around $1690 USD for an i5. For the i7 it would be $1850.
There's obviously a little bit of play there, as you can get a cheaper GPU (I picked the rtx 4070 super ventus 2x at $620), a smaller NVMe drive, use the Corsair RM850e rather than the MAGA1000GL, and that'll help bring it down a little bit, down to around $1520 for the i5 and $1650 for the i7.
That should cover most of the needs above overall, IF you need to get it right now. I'd still recommend waiting for the next gen Intel gear though.
