When power Button Pressed,Only Orange light.
jgsnuwan
I Opened Back Cover Because my Fan Not Worked Well.After that i set all & Try to Power on my Laptop..After Press Power Button Power LED Light up with Orange Color.As i remember before It Become Orange & turn it to white when display is turn on.Now its only Orange color & Nothing in Display.Any One Have thiss issue? How can i fix it 😢
ec reset "dead battery "
AC connected - no recharge
EC - fully shutdown ,.,.no AC .,,.small hole on back-cover "30s"
after this add AC "wait" 5min ,..,run system
Can you use an external monitor?
If still no luck, reset EC and contact the nearest service center.
Bios is corrupted. You have to rewrite the bios manually.
You can try this also.
